Sample UDF for Characterizing the Tube-Side 2-Phase Fluid
Old   June 22, 2015, 15:09
Default Sample UDF for Characterizing the Tube-Side 2-Phase Fluid
Joseph Thodiyil
thodij is on a distinguished road
I am modeling a six-pass (50 tubes per pass) air-cooled condenser to figure out the tube-side flow/vapor quality maldistribution and temperature distribution on the tubes, tube-sheet and header boxes at steady stste. First I need to define the tube-side fluid (coming in at 60% vapor quality). The vapor quality is going to drop until full condensation is achieved in the final passes. I figure that a UDF needs to be written to characterize this condenser fluid. Does anyone have experience writing such a UDF? PLease advise.
We know the "bulk" bahavior of the heat exchanger from use of HTRI software. Unfortunately, HTRI assumes that the incoming header flow is split uniformly across all the first pass tubes.
Any tips/ tricks for writing this condensor fluid UDF will be helpful.
Thanks.
thodij is offline   Reply With Quote
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
CFX Solver Memory Error mike CFX 1 March 19, 2008 07:22
Help !! UDF for second phase viscosity. yong FLUENT 2 January 24, 2007 11:11
Grap Fluid Cells Just On One Side Of A Baffle Tommy Siemens 0 May 7, 2006 07:49
