Unsteady function for UDF
Old   March 12, 2008, 13:02
Default Unsteady function for UDF
Sandilya Garimella
Hello All I am trying to solve for time varying electric potential for the potential equation ?(i.e) poisson's equation the unsteady from is helmholtz equation
[d^2 /(dt)^2] (phi) + grad^2 (phi) = source
I discretized the unsteady term (which is double derivative in time) using backward differencing and separated the terms into two terms as given in manual
Following this I wrote a simple UDF as given below
DEFINE_UDS_UNSTEADY(unsteady_function,c,t,i,apu,su )
real vol;
real delt;
real time;
real phi1;
real phi2;
vol = C_VOLUME(c,t);
delt = CURRENT_TIMESTEP;
time = CURRENT_TIME;
if(i==0)
phi1 = C_STORAGE_R(c,t,SV_UDSI_M1(i)); /* value of phi at (n-1) time step */
if(time<5.0e-6)
phi2 = 0;
else
phi2 = C_STORAGE_R(c,t,SV_UDSI_M2(i)); /* value of phi at (n-2) time step */
/* C_UDSI_M2(c,t,i);*/
*apu = (mu * epsilon * vol) / (delt * delt);
*su = (-2 * phi1 + phi2 )*mu * epsilon * vol / (delt * delt);
But when I run after hooking the UDF, till 5.0e-6 seconds the transient solutions converges.
But when it has to access the (n-2) time step term then the there is an error "ACCESS VIOLATION"
Can anyone help me to figure out if there is an error
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()
Old   August 1, 2015, 09:58
Default resolved
Gylles
gylles is on a distinguished road
You should go: Solve --> Solution Methods --> Transient Formulation -->Second Order Implicit (on).
Good luck!!
Originally Posted by Sandilya Garimella
;149133
real vol;
real delt;
real time;
real phi1;
real phi2;
if(i==0)
if(time<5.0e-6)
phi2 = 0;
else
Error:
Error Object: ()
gylles is offline   Reply With Quote
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
-Xlinker --add-needed -Xlinker --no-as-needed NH1994 OpenFOAM Programming & Development 7 December 31, 2014 10:24
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
unsteady Bernoulli equation and wagner function. Afungchui Main CFD Forum 0 March 14, 2005 11:50
