Is there an equivalent of "NODE_POS_NEED_UPDATE" for face values? |
July 24, 2015, 12:21 |
V.Leb
Rep Power: 10 |
I'm trying to use DEFINE_PROFILE in a transient case and the problem I encounter is that my velocity component data file (which has data for *all* time steps, not just a single one) is read every iteration as opposed to time step, so I was wondering if there is an equivalent to NODE_POS_NEED_UPDATE used in DEFINE_GRID_MOTION? Or is there an alternative way? Code:
#include "udf.h" DEFINE_PROFILE(v_component, thread, position) { face_t f; real x[ND_ND]; real y; double v; real t = CURRENT_TIME; FILE *v_values; v_values = fopen("v_intp.txt","r"); begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; fscanf(v_values, "%lf\n", &v); Message("The v is %lf\n", v); Message("The x is %f\n", x[0]); F_PROFILE(f, thread, position) = v; } end_f_loop(f, thread) } Last edited by Leb; July 24, 2015 at 13:50. Reason: Clarification |
July 24, 2015, 16:02 |
#2 | |
Rep Power: 17 |
July 24, 2015, 16:36 |
V.Leb
Rep Power: 10 |
Thanks for your reply, but as I mentioned, I do *not* want to update the profile every iteration, but every time step.
I was hoping that I could use something like this: Code:
if (t = 0.000000) u_values = fopen("u_comp_0.txt","r"); else { u_values = fopen(strcat(strcat(foo,str),bar ),"r"); } Code:
strcat(strcat(foo,str),bar ) |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
cyclic BC - modify boundary face values | marluc | OpenFOAM Programming & Development | 0 | May 4, 2015 16:50 |
Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 03:59 |
Setting patch field values equal to internal field values | leroyv | OpenFOAM Programming & Development | 1 | October 21, 2014 15:49 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
