UDF compilation error
Old   April 2, 2004, 09:37
Default UDF compilation error
Szabolcs Varga
Dear All, I am getting a compilation error of a UDF related (I think)to RP macros. Unfortunatelly I could not find the origin and meening of this error:
Error: G:\fluentwork\trigen\phase3\eforce_szabi.c: line 7: structure reference not implemented
There is almost no documentation on what RP_CELL(&(p->cCell)) and RP_THREAD(&(p->cCell)) are and how to use them correctly. There are a two examples in the fluent manual for the use of these macros, but I could not comile those examples either (4.6.12 Define_DPM_SWITH in the UDF manual). Could you please help me out what the problem might be? I am attaching the UDF below. Szabolcs
#include "udf.h" #include "dpm.h" #include "surf.h"
DEFINE_DPM_BODY_FORCE(force_L_P,p,idir) { cell_t c=RP_CELL(&(p->cCell)); Thread *t=RP_THREAD(&(p->cCell)); real l_force, mp, ex_t, er_t, Elp; real charge_on_p;
int V_x=0, V_r=0, E_x=0, E_r=1, E_magn=2;
mp=P_MASS(p);
charge_on_p= P_DIAM(p)*1.6e-11; /* you have to define real function P_charge() for particle charge*/ ex_t=C_UDMI(c,t,E_x); er_t=C_UDMI(c,t,E_r);
/* user code for x component force (m/s/s) */ if (idir==0) { l_force=ex_t*charge_on_p/mp; /*Fx*/ } /* user code for r component force (m/s/s) */ if (idir==1) { l_force=er_t*charge_on_p/mp; /*Fr*/ } return l_force }
Old   April 2, 2004, 21:42
Default Re: UDF compilation error
Ajay
structure reference not implemented is usually got when you try to "interpret " the UDF's rather than "compiling" them -Ajay
Old   April 6, 2004, 02:09
FJ
Yes,Yes. Ajay is right. We cannot use "interpretted" when we refer to structured variables. Let compile it.
Thank you
FJ
Old   April 11, 2015, 13:49
Exclamation same problem
bia
nabaouia
bia is on a distinguished road
I've got the same problem , so I try to compile but I had this text message error :Error: open_udf_library: Le fichier spécifié est introuvable.
Error Object: ()
(the specific folder not found (libudf ) ?
I turn back and unload the libudf and recompile again but always the same problem . please help me
thanks
bia is offline   Reply With Quote
Old   September 14, 2015, 05:27
shadi
shadi is on a distinguished road
your udf and your case must be in the same folder
shadi is offline   Reply With Quote
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
