October 10, 2015, 08:00 |
Macros for access turbulence intensity
Astio Lamar
Rep Power: 14 |
Hello all!
I want to calculate some a value in a UDF and I need to have "turbulence intensity". Is there anyone here know how can I return this value? I mean a macro such as " C_U(c,t)" which return turbulence intensity. moreover, is there any macro which return velocity magnitude? or the only way is to return components and then find the magnitude? |
October 11, 2015, 16:36 |
Rep Power: 18 |
Fluent doesn't store turbulence intensity by default. However, you can calculate this value as turbulence intensity is defined as the ratio between the root-mean-square turbulent velocity fluctuations and the mean velocity.
The velocity fluctuations can be computed as a function of the kinetic energy (for example, k-e) or via the Reynolds stresses (RSM model). The mean velocity (not stored as a separate value by default) is the magnitude of the individual components. |
Turbulence intensity too high on the inlet | trollreign | FLUENT | 1 | December 10, 2023 21:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Creating a new field from terms of the turbulence model | HaZe | OpenFOAM Programming & Development | 15 | November 24, 2014 13:51 |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
