June 18, 2019, 03:36 |
Error in compiling UDF
Kirti Verma
Rep Power: 6 |
Hi all!
I am trying to define the rate of reaction using UDF, i tried to interprete the UDF but it didn't work so I have been trying to compile it. I have opened fluent through x86 Native Tools Command Prompt for VS 2017, now I changed the working directory to the folder where my case data and udf file has been stored. I then tried to compile, it shows following: Copied Z:\Desktop\All Simulations\udf reaction try_files\dp0\FFF-1\Fluent/New Text Document.c to libudf\src udf_names.c and user_nt.udf files in 3ddp_host are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v193\fluent"\fluent 19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_host") udf_names.c and user_nt.udf files in 3ddp_node are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v193\fluent"\fluent 19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_node") Done. and on Loading it, this error shows: Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified. \n\nZ:\Desktop\All Simulations\udf reaction try_files\dp0\FFF-1\Fluent\libudf\win64\3ddp_host\libudf.dll Error Object: #f I have tried changing from parallel to serial as well, but it doesn't work, Please someone help me I would be very Grateful |
June 18, 2019, 04:00 |
Alexander
Rep Power: 34 |
make any change in source file (press space and delete it)
recompile best regards |
June 18, 2019, 04:03 |
Kirti Verma
Rep Power: 6 |
Thankyou for the prompt reply, I have checked making changes in source files, I am getting the same result. The problem still persists.
This is my UDF Code: #include "udf.h" DEFINE_VR_RATE(vol_reac_rate,c,t,r,wk,yk,rate,rr_t ) { real ci, prod; int i; /* Calculate Arrhenius reaction rate */ prod = 1.; if (FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous) for(i = 0; i < r->n_reactants; i++) { ci = C_R(c,t) * yk[r->reactant[i]] / wk[r->reactant[i]]; prod *= pow(ci, r->exp_reactant[i]); } *rate = r->A * exp( - r->E / (UNIVERSAL_GAS_CONSTANT * C_T(c,t))) * pow(C_T(c,t), r->b) * prod; else *rate = 0.; *rr_t = *rate; /* No "return..;" value. */ } |
June 18, 2019, 23:58 |
Alexander
Rep Power: 34 |
#include "udf.h" DEFINE_VR_RATE(vol_reac_rate,c,t,r,wk,yk,rate,rr_t ) { real ci, prod; int i; /* Calculate Arrhenius reaction rate */ prod = 1.; if (FLUID_THREAD_P(t) && THREAD_VAR(t).fluid.porous) { for(i = 0; i < r->n_reactants; i++) { ci = C_R(c,t) * yk[r->reactant[i]] / wk[r->reactant[i]]; prod *= pow(ci, r->exp_reactant[i]); } *rate = r->A * exp( - r->E / (UNIVERSAL_GAS_CONSTANT * C_T(c,t))) * pow(C_T(c,t), r->b) * prod; } else *rate = 0.; *rr_t = *rate; /* No "return..;" value. */ } this is output you should get Code:
Copied path_to_working_folder. temp_delete.c to temp_delete\src udf_names.c and user_nt.udf files in 3ddp are upto date. (system "copy "fluent_path"temp_delete\win64\3ddp\makefile" ") 1 file(s) copied. (chdir "temp_delete")(chdir "win64\3ddp")# Generating ud_io1.h temp_delete.c # Generating udf_names.c because of makefile temp_delete.obj udf_names.c # Linking libudf.dll because of makefile user_nt.udf udf_names.obj temp_delete.obj Microsoft (R) Incremental Linker Version 10.00.40219.01 Copyright (C) Microsoft Corporation. All rights reserved. Creating library libudf.lib and object libudf.exp Done. |
June 19, 2019, 02:39 |
Kirti Verma
Rep Power: 6 |
Can you please answer a few doubts, it will be really helpful for me as i am a beginner, this is what is shows to me:
Copied Z:\Desktop\All Simulations\compilation_files\dp0\FLU\Fluent/New Text Document.c to libudf\src udf_names.c and user_nt.udf files in 3ddp_host are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v193\fluent"\fluent 19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_host")udf_names.c and user_nt.udf files in 3ddp_node are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v193\fluent"\fluent 19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_node") 1. Did you open Fluent from VS Prompt or simply from workbench? 2. Did you tried it with some boundary conditions/ geometry or geometry doesn't have any affect of compilation? 3. Did you select Parallel or Serial processing? 4. Can you send a link where the method of compilation that you used is mentioned, I have tried many methods but none worked. I will be really grateful to you and this platform for this. I have tried all the possible combinations of methods of compilation. |
June 19, 2019, 03:06 |
Kirti Verma
Rep Power: 6 |
As far as I can conclude, there must be some problem in setting up environment variables. I haven' t done it because I don't have admin access. Will you please let me know the procedure?
June 20, 2019, 00:41 |
#7 | |
Alexander
Rep Power: 34 |
it doesn't matter what settings or geometry you have for compiling process. It doesn't matter single or parallel regime you are using (but you should know, if your compile in parallel regime -> you will get UDF for parallel only, same for serial) as I told you, Fluent consider your source file is up to date. So Fluent doesnt compile it. You should make any change in source file, save it and compile (click BUILD) if you are not sure about your software, you may use following link https://www.cfd-online.com/Wiki/Flue...ows_7_64bit.3F best regards |
June 27, 2019, 06:17 |
Kirti Verma
Rep Power: 6 |
Hey! I have tried these solutions, added environment variables from the "Advanced System Settings" too but it didn't work. I am working on the following system.
Fluent Version - ANSYS 2019 R1 Windows 10, 64 bit Microsoft Visual C++ 2017 I have attached the screenshot of the error I am getting, basically the file "libudf.dll" is not being formed in the folder. Copied Z:\Desktop\All Simulations\compilation_files\dp0\FFF\Fluent/New Text Document.c to libudf\src udf_names.c and user_nt.udf files in 3ddp_host are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v193\fluent"\fluent 19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_host\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_host")'nmake' is not recognized as an internal or external command, operable program or batch file. udf_names.c and user_nt.udf files in 3ddp_node are upto date. (system "copy "C:\PROGRA~1\ANSYSI~1\ANSYSS~1\v193\fluent"\fluent 19.3.0\src\udf\makefile_nt.udf "libudf\win64\3ddp_node\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\3ddp_node")'nmake' is not recognized as an internal or external command, operable program or batch file. Done. This is after Build command, and the screenshot is of after the Load command. Please let me know if I have to reinstall Visual Studio and make it work with the Fluent or what steps to follow. I would be very grateful. Thanks |
February 6, 2020, 12:42 |
#9 |
mln
Rep Power: 6 |
Hello Kirti Verma
I am facing the same issue. Could you please let me know the correction if you have figured it out? |
February 6, 2020, 14:40 |
Command prompt or udf.bat
#10 |
nmake not recognized means the paths are not set properly. Either you have to ensure that udf.bat is able to execute properly without any error. This is location in Fluent's installation directory. Other solution is to start Fluent from the command prompt of VS or VC++ or MS SDK.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 7, 2020, 11:32 |
#11 |
mln
Rep Power: 6 |
Apologies! Kindly ignore this message. I have sent the correct message again.
February 7, 2020, 11:39 |
#12 |
mln
Rep Power: 6 |
Thank you very much. I have got it corrected.
One question. I loaded a udf for drag model. I chose the respective drag model in the respective dialogue box. I saved the file. When I read the case and data file later, I can see in the console window that the udf is read. However, when I check the drag model dialogue box, it just shows user defined instead of the name of the new drag model. Is this how it should be? |
February 9, 2020, 15:02 |
That's alright
#13 |
If Fluent shows UDF instead of in-built drag models, then UDF is selected. If it is shows blank, it implies that Fluent expectes and UDF but the UDF library is not loaded.
compile a udf |
UDF compiling error | Weiqiang Liu | FLUENT | 2 | November 21, 2018 09:36 |
UDF Compiling / Parallel mode | MV78 | Fluent UDF and Scheme Programming | 6 | May 29, 2018 05:02 |
ERROR in compiling UDF | stefanos | Fluent UDF and Scheme Programming | 1 | April 25, 2012 07:37 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 07:14 |
On Compiling a UDF | David Chabot | FLUENT | 5 | May 20, 2005 09:13 |
