Smearing of Mass Transfer(condensation)using UDS over interface.
Like Tree1Likes
  • 1 Post By RAJ KIRAN
Old   May 23, 2016, 11:19
Default Smearing of Mass Transfer(condensation)using UDS over interface.
Rajukiran Antham
RAJ KIRAN is on a distinguished road
Hej,
I am working on phase change problem (condensation). I wrote UDF's for calculation of source terms. I want to smear mass transfer near the interface using a Diffusion equation and then pass the smeared values as source terms to the equations. I am solving the diffusion equation using UDS and passing mass transfer as source term to UDS.
Below is the diffusion equation which I am solving,
D*del2(phi)= S
here,
D is diffusion coefficient, phi is scalar variable and S is source term,
I am passing source term using Define_source UDF,
DEFINE_SOURCE(UDS_src,c,t,dS,eqn) /*smearing source udf*/
real UDS_source;
UDS_source = 0.0;
UDS_source = C_UDMI(c,t,1)-C_UDSI_M1(c,t,0) ;
dS[eqn] = 0.0;
return (UDS_source);
In the above UDF C_UDMI(c,t,1) is the mass transfer term which is calculated in a different UDF. Diffusion coefficient D is passed using below UDF.
#include "udf.h"
DEFINE_DIFFUSIVITY(mean_age_diff,c,t,i)
return 0.0000001;
What I was expecting was a smeared mass transfer over few cells close to the interface , since mass transfer is calculated only at the interface. but I am not getting the expected result. I am not sure where I am going wrong. I would really appreciate if someone can point out where I am going wrong.
regards,
Rajukiran.
PS: I am also attaching pic of scalar value of phi and interface where source terms are added.
artem929292 likes this.
RAJ KIRAN is offline   Reply With Quote
Old   May 24, 2016, 08:19
Rajukiran Antham
Hej,
I tried a simple case, where I tried solving a steady diffusion equation using UDS. I switched off inlet Diffusion, Flux and unsteady function in the UDS. I used Neumann boundary conditions over the domain. I gave a constant source term through UDF only at the interface. I was expecting that the given source term to smear over the interface. But I got something similar to previous case. I would really appreciate if someone can answer this.
Thanks in advance
Regards,
Rajkiran
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 06:08
Modeling the fan with a mass flow interface saisanthoshm88 CFX 6 August 1, 2014 06:11
Modelling valves/orifices using interface models DarrenC CFX 5 June 3, 2014 06:14
why my momentum and mass not convergence wwwuxing CFX 3 May 18, 2012 07:49
