Error "UDF library you are trying to load is not compiled for 2ddp..."
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   January 29, 2016, 10:22
Default Error "UDF library you are trying to load is not compiled for 2ddp..."
ananthanarasimhan
ananthanarasimhan is on a distinguished road
im getting below error while trying to load the udf file.
The UDF library you are trying to load is not compiled for 2ddp on the current platform (win64)
ananthanarasimhan is offline   Reply With Quote
Old   January 31, 2016, 22:02
`e`
`e` is on a distinguished road
Try compiling the UDF again, if you're having trouble updating compiled UDFs then check my compiling process for Fluent UDFs with an existing library loaded.
`e` is offline   Reply With Quote
Old   June 7, 2019, 04:31
Exclamation compiling problem
ehsan
From_IRAN is on a distinguished road
You are trying to load a UDF which is not compiled. Either you forgot to compile, or you tried to compile it and it failed, but you didn't notice the errors showing on your screen. Besides, compiling failure can be due to different reasons. Most common reasons:
1-Compiler is not installed on your system.
2- Use unusual characters for folder/sub folder or for UDF name such as, @, *,+, or even using "space".
3-Errors in UDF code.
From_IRAN is offline   Reply With Quote
Old   March 18, 2021, 00:58
umerali
umeralizuberi is on a distinguished road
is there any video regarding compilation of udf in visual studio?
umeralizuberi is offline   Reply With Quote
Old   March 18, 2021, 20:40
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
check youtube
umeralizuberi likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   March 25, 2021, 00:13
umerali
i have a code for flapping motion in 2D can you check it, i can not find any error in it.
/* the code is written for 2D flapping chord length of 0.01 m
and Reynolds number of 157 i.e velocity = 0.229 m/s
#include "udf.h"
static real alpha_dot = 0.0; /* rotational velocity */
static real x_velocity = 0.0; /* velocity in X direction */
static real y_velocity = 0.0; /* velocity in Y direction*/
DEFINE_CG_MOTION(flapping, dt, vel, omega, time, dtime)
Thread *t;
face_t f;
real pi = 3.14159;
real c = 0.01; /* wing chord in meters */
real amp = 0.025; /* Amplitude in meters */
real period= 0.025; /* time period in second */
real alpha; /* angle of attack */
real beta = (pi/3); /* inclination angle of stroke plane */
/*reset velocities*/
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P ())
return;
x_velocity= -(amp*pi/(period))*cos(beta)*sin(2*pi*time/period);
y_velocity= -(amp*pi/(period))*sin(beta)*sin(2*pi*time/period);
alpha = (pi/4)-((pi/4)*sin(2*pi*time/period));
alpha_dot = -((pi/4)*2*pi/(period))*cos(2*pi*time/period);
Message("time:%f alpha:%f alpha_dot:%f x_velocity:%f y_velocity:%f\n",time,alpha,alpha_dot,x_velocity, y_velocity);
vel[0] = (x_velocity);
vel[1] = (y_velocity);
omega[2]= -(alpha_dot);
(whenever i click on build there is a msg i.e.
(chdir "libudf")(chdir "win64\2ddp") 'nmake' is not recognized as an internal or external command, operable program or batch file.)
after this if i load it gives the same error
udf
The UDF library you are trying to load (libudf) is not compiled for 3D on the current mohibanwar Fluent UDF and Scheme Programming 14 December 8, 2020 17:33
The UDF library you are trying to load (libudf) is not compiled for 3d on the current vigii Fluent UDF and Scheme Programming 37 October 3, 2019 06:16
Error: The UDF library you are trying to load (libudf) is not compiled for 2d on the gxu2 Fluent UDF and Scheme Programming 13 August 10, 2018 17:38
Error: The UDF library you are trying to load is not compiled for 3ddp on the current Whitemast Fluent UDF and Scheme Programming 0 November 21, 2013 06:45
Compiled library vs. inInclude Files, DSMC solver crashes after run GPesch OpenFOAM Programming & Development 8 April 18, 2013 07:17
