Get different value from FLUENT static pressure integration. |
Nate Lau
Rep Power: 10 ![]() |
I wrote following UDF to acquire pressure integration value of one flat boundary. However, the pressure integration function build in FLUENT gives me a totally different answer. Are there any problem in my code?
![]() #include "udf.h" #define rvol1_ID 22 DEFINE_EXECUTE_AT_END(pressureudf) { FILE *fp1; real time1=CURRENT_TIME; Domain *d; Thread *thread; face_t f; double A[ND_ND]; double pressure=0.; d= Get_Domain(1); thread=Lookup_Thread(d, rvol1_ID); begin_f_loop(f,thread) { F_AREA(A,f,thread); pressure+=F_P(f,thread)*NV_MAG(A); } end_f_loop(f,thread) fp1=fopen("pressure223.txt","a"); fprintf(fp1,"%g %g\n",time1,pressure); fclose(fp1); } |
Rep Power: 18 ![]() |
The units of your variable 'pressure' is N (a force). Ensure your units are what you expect and whether or not gauge/dynamic/static pressure is used. For details on how Fluent treats pressure, have a read of this post.
Nate Lau
It is very weird that the problem is at fprintf(fp1,"%g %g\n",time1,pressure); which cannot show a correct answer. When I adjust the distance between time1 and pressure, it works and gives the same answer as FLUENT integral function.
fluent, fluent - udf, integrate variables, udf, udf and programming |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 12:23 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
Assign static pressure at inlet | Tanjina | FLUENT | 0 | November 3, 2013 11:34 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
