Can I change flow direction using UDF?
Old   April 1, 2016, 05:53
Default Can I change flow direction using UDF?
Tzung
newcfdone is on a distinguished road
I want to use mass flow inlet boundary condition to create unsteady inflow and outflow. The mass flow rate can't be negative. Can I use UDF to define flow direction in Mass Flow Inlet Boundary Conditions Panel?
Thank you advance
Tzung
newcfdone is offline   Reply With Quote
Old   April 1, 2016, 06:24
Bruno Machado
Bruno Machado is on a distinguished road
Originally Posted by newcfdone View Post
Thank you advance
Tzung
Just change the flow direction in this panel.
Bruno Machado is offline   Reply With Quote
Old   April 1, 2016, 13:05
Tzung
Hi Bruno,
The mass flow inlet just accepts the positive mass flow rate. If I want to create outflow or inflow, as you mention, I have to specify the flow direction. I want to simulate an unsteady problem, however, it needs to dynamically change the flow direction. Can I do so through the Mass Flow Inlet Panel? or I have to do so using UDF, can I?
Best Regards,
Tzung
Old   April 4, 2016, 05:19
Bruno Machado
Hi Bruno,
Best Regards,
Tzung
But that is precisely what I've said. You can change the flow direction using a negative value (you can use -1 instead 1). The value of the mass flow rate, as you said, should be positive.
You can either do it manually by changing it whenever you want or by using a UDF with dependence on time.
Old   April 6, 2016, 22:49
Tzung
Hi Bruno,
I can successfully change the flow direction.
Thanks for your help a lot!
Can I ask you some questions?
How can I read experiment data to specify the flow rate at Mass Flow Inlet BC using UDF?
I use "fscanf", but it does work correctly.
1. Should I fopen data file outside or inside DEFINE_PROFILE?
2. Should I fscanf data file outside or inside DEFINE_PROFILE?
3. Should I fclose data file at Exit?
I am not sure whether if I miss something else.
Or you can provide a UDF example?
Sincerely,
Tzung
ERROR: Flow direction on the boundaries must not be tangential to the boundary. turbomax CFX 2 August 6, 2015 11:05
UDF problems with porous flow Nicolastheterminator Fluent UDF and Scheme Programming 0 April 8, 2014 09:12
UDF for perpertual velocity step change romanpicisan Fluent UDF and Scheme Programming 0 February 17, 2014 04:55
Do Pressure Inlet Flow Direction Components Need to Be Normalized? ScottN FLUENT 0 September 21, 2010 09:18
Help please UDF flow direction val17lr FLUENT 2 September 4, 2010 05:30
