UDF: Have 3 dynamic mesh regions working well in 2D, but not in 3D
Old   October 16, 2015, 20:45
Question UDF: Have 3 dynamic mesh regions working well in 2D, but not in 3D
Gabriel Naccache
gabriel09 is on a distinguished road
Hello everyone,
So I have done a simulation in 2D where I prescribed the motion of two domains using a UDF. The purpose of this simulation was to analyse the performance of a vertical axis wind turbine with one blade in a non circular path. The entire mesh is composed of an outer deforming stationary mesh, and an inner moving mesh that translates in a vertically oscillating motion. Inside this translating mesh, is another rotating sliding mesh.
I have completed the simulation in 2D and everything works fine. So I am testing this design in 3D, but it is not working correctly. The UDF is compiled correctly without any errors. When I launch the simulation, I can see that the mesh does indeed move; however, when I monitor the velocity of the blade, Fluent gives me zero velocity value. So I decided to make a dummy simulation and test each domain motion individually with the UDF and they both worked and fluent gave me the correct velocity on the blade.
I have attached the UDF to look at.
If anyone could help me with this problem, I would greatly appreciate it. Thanks everyone.
gabriel09 is offline   Reply With Quote
Old   May 12, 2016, 06:06
Default Dragon fly motion
Arun raj.S
arunraj is on a distinguished road
Hi Gabriel,
I am simualting dragonfly motion. I want to use sliding mesh as I want to create structured mesh around the aerfoil. What changes I have to make in this udf. I have attached my domain. Could you tell me?. I have attached the udf which i have prepared but i am not sure whether it is proper or not
x(t),y)(t) = (Ao/2)*(1+cos(2*pi*f*t)*(cos(beta),sin(beta))
alpha(t) = alphao+B sin(2*pi*f*t)
Ao=2.5 cm
B=pi/4
alphao=pi/4
f=40 Hz
beta = 60 degree
I have differentiated the above function and applied in the udf
vel[0] = - A0/2 * 2*pi*f*cos(beta)*sin(2*pi*f*t)
vel[1] = - A0/2 * 2*pi*f*sin(beta)*sin(2*pi*f*t)
omega[2]= B *2*pi*f*cos(2*pi*f)
File Type: c Mesh_Motion - Copy.c (738 Bytes, 15 views)
arunraj is offline   Reply With Quote
3d analysis, fluent, udf cg motion
2d Dynamic Mesh with udf pvc Fluent UDF and Scheme Programming 44 May 19, 2021 18:10
dynamic mesh udf hillat Fluent UDF and Scheme Programming 3 March 1, 2014 16:53
Dynamic mesh for rotating wall - UDF ? Tobard FLUENT 1 April 28, 2011 18:00
dynamic mesh udf sample wlt_1985 FLUENT 0 April 10, 2011 23:36
a problem about DEFINE_GEOM in dynamic mesh UDF speedcat FLUENT 1 May 16, 2005 03:09
