Compiling the customized source code problem
Old   June 16, 2012, 04:19
Default Compiling the customized source code problem
Ryan
cfdmatteo is on a distinguished road
hi there,
I am trying to change the PEMFC module source code(pem_user.c file) to make my own module. As I following the steps of the manual as shown:
* Define environment variable FLUENT_INC to point to the official
fluent installation directory.
- note on Windows this looks like [path]\ANSYS Inc\vXX.X\fluent
* Build the library from the fuelcells directory with the following
command: nmake /f makefile_master-client.nt
I think the last step means typing "nmake /f makefile_master-client.nt" in the Visual Studio.NET at the DOS prompt
But the error shows:
NMAKE : fatal error U1052: file 'makefile' not found
Can anybody help me to figure this out?
Or someone has the experience of modifying the Fuel cell module?
Any suggestion will be appreciated.
Ryan
cfdmatteo is offline   Reply With Quote
Old   July 9, 2016, 09:49
kobe bryant is on a distinguished road
Hi,have you solved this problem?I also want to change pem_user.c file and make my own module.hope your reply.Thanks.Much obliged.
kobe bryant is offline   Reply With Quote
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
Please help me run UDF code for source Suga FLUENT 1 February 3, 2006 03:40
problem with using colocated code Jack Main CFD Forum 0 December 15, 2002 00:15
