Problem with building 3ddp UDF in Ansys FLUENT 16.2 |
July 18, 2016, 11:46 |
Quang Le Dang
Rep Power: 13 |
Dear all,
I have a strange problem. First, I run 2D with UDF (2ddp_host and 2ddp_node), everything is built and run as normal. After that I start 3D model with the same UDF and copy libudf from 2D cases with adding 3ddp, 3ddp_host and 3ddp_node. I do not understand why I cannot build it and get this message make[1]: Entering directory `path/libudf/lnamd64/3ddp' makefile:14: user.udf: No such file or directory make[1]: *** No rule to make target `user.udf'. make[1]: Failed to remake makefile `user.udf'. # Generating udf_names.c because of makefile I try the same folder with 2ddp is OK. Could you give me advices about this problem? Thank you in advance. |
July 20, 2016, 04:08 |
Bruno Machado
Rep Power: 13 |
you gotta compile it again for 3D case.
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 04:28 |
how to understand UDF in ansys fluent? | sriyaz | Fluent UDF and Scheme Programming | 4 | November 10, 2015 02:27 |
Problem using ANSYS Fluent 15.07 | Saikat_FM | FLUENT | 2 | July 13, 2015 05:10 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
fluent udf problem: write specific data for every iteration in a file. | nnvoro | Fluent UDF and Scheme Programming | 1 | May 27, 2013 15:26 |
