UDF for Rotation
Old   November 18, 2014, 10:52
Default UDF for Rotation
Giovanni
Johnmuddy is on a distinguished road
i'm looking for a function that allows to rotate the body between two corners according to the flow.
i'ts a dynamic mesh whith smoothing and remeshing.
the time step is 0.001
end the center of rotation is (0,0)
this is the 6dof function
DEFINE_SDOF_PROPERTIES (Rotazione, prop, dt, time, dtime)
prop[SDOF_MASS] = 0.01;
prop[SDOF_IZZ] = 0.00833;
prop[SDOF_ZERO_TRANS_X] = TRUE ;
prop[SDOF_ZERO_TRANS_Y] = TRUE ;
prop[SDOF_ZERO_TRANS_Z] = TRUE ;
prop[SDOF_ZERO_ROT_Y] = TRUE ;
prop[SDOF_ZERO_ROT_X] = TRUE ;
printf ("\n2d_Rotazione: Updated 6DOF properties");
Now i need to rotate betwen 55° and 5° .
this is the error that fluent gives me end what appens to the mesh
Please help me !
Johnmuddy is offline   Reply With Quote
Old   November 20, 2014, 09:04
Giovanni
Please, anyone can help me? thanks in advance...
Old   November 21, 2014, 07:10
Linh Tuan The Nguyen
linh nguyen is on a distinguished road
Did you tried to reduce under relaxation factor? It's might take longer running time, but might solve the problem
linh nguyen is offline   Reply With Quote
Old   November 21, 2014, 12:22
Giovanni
which particular parameter i have to reduce ?
I think the problem that causes negative volumes is due to the fact that I don't have imposed a limit on the rotation as the cells at the edges deform excessively. Anyone knows how to do it ?
i posted the image of the initial condition of the valve, and what i want to do it
and what happens instead.
Old   November 22, 2014, 06:10
Giovanni
Now i'm able to make the simulation without volume errors . but i'm not able to define the angle limits on rotations.
I thought, bypassing the problem, to describe the boundaries on the translation of the center of gravity of the wing so that when it reaches one of the limits of this interval, have v = 0 .. but what macro should i use end how?
Old   October 25, 2016, 08:44
Wesley liu
luna125 is on a distinguished road
could you describe your solution on how to solve the negative volume?
luna125 is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
