UDF for mass transfer between phases in two phase ice-slurry pipe flow |
Devshi Ziyad
Rep Power: 10 ![]() |
I have wrote a UDF for melting of ice-particles in two-phase ice-slurry pipe flow
The code is as follows: #include "udf.h" /* UDF to define a simple mass transfer*/ DEFINE_MASS_TRANSFER(UFD, cell, thread, from_index, from_species_index, to_index, to_species_index) {real mass; real hsl = 1; real pr=1; real C_YI(c,t,1); real ds = 0.0001; read latent_heat = 21000 real alphas = 0.1; real ds = 0.0001; real v = 1.25; real lambdal = 0.5034; real mus=1.72*10^-5; real mul=0.70354; real rhos=917; real cpl=4260; real latent_heat=332400; Res= rhos*|C_U(c,t,2)-C_U(c,t,3)|*ds/mus; Pr=mul*Cpl/lambdal hsl= (lambdal/ds)*(7+(10*alphas)+(5*alphas^2))*(1+0.7*(Res^0.2)* (Pr^1.3)) hv=6*alphas*hsl/ds; mass= hv*((C_T(c,t,2)-C_T(c,t,3))/latent_heat); return mass; } I am keep getting error that : Error: The UDF library you are trying to load (C:\Users\Devshi\Downloads\pipe\pipe2_files\dp0\FF F\Fluent\libudf) is not compiled for 3d on the current platform (win64). The system cannot find the file specified. Kindly help |
Rep Power: 9 ![]() |
is it the first time that you compile an UDF?
Devshi Ziyad
Yes, this is my first time. Kindly advice
ok...then I had the same problem, for me it worked to disintall all visual c programs and install the Microsoft Visual Studio Express 2015 and then to add the path where "fluent.exe" and "runwb2.exe" to the "path" enviroment variable....then I rebooted the system and it worked...
https://www.researchgate.net/post/Ho..._ANSYS_Fluent2 (Here it's explained better) |
Devshi Ziyad
Thank you for your kind help. I'll let you know about the progress soon.
Thanks again! |
Rep Power: 18 ![]() |
Also ensure you're correctly unloading and compiling the new UDF by following my compiling process for Fluent UDFs with an existing library loaded.
eulerian multiphase model, udf and programming |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
behavior of two phase flow in a pipe | Sonia84 | FLUENT | 5 | September 17, 2013 16:31 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
