January 31, 2017, 12:27 |
UDF Compiled
Varion
Hi guys,
I'm new in UDF implementing and I am having some problems when I try to couple my udf with FLUENT. Whenever I try to define my UDF using a compiled file, FLUENT returns no error, I am able to build and load my code, but when I initialize the solution it all stop working and the window closes. Does anybody have any idea of what could be causing this? Thanks in advance |
February 2, 2017, 11:21 |
Rep Power: 26 |
It could be a problem in your UDF, but because you did not share it, it is impossible to say that.
February 2, 2017, 12:03 |
Varion
It's working now. The problem was exactly what you have mentioned.
Thanks |
fluent, udf |
Error: The UDF library you are trying to load is not compiled for 3ddp on the current | Whitemast | Fluent UDF and Scheme Programming | 0 | November 21, 2013 06:45 |
UDF compiled problem | Enricodex | Fluent UDF and Scheme Programming | 2 | August 11, 2013 17:48 |
I want to use pressure of 1 face in udf that compiled on other face | iman_1844 | Fluent UDF and Scheme Programming | 3 | June 10, 2010 12:55 |
Why udf can not be compiled in my pc? | Xinqiang | FLUENT | 0 | June 10, 2009 14:32 |
compiled UDF | bharti | FLUENT | 2 | November 15, 2006 13:04 |
