[FLUENT] UDF NOT working in new version of Fluent
Old   February 6, 2017, 10:28
Default [FLUENT] UDF NOT working in new version of Fluent
Giorgio
Faggio11 is on a distinguished road
Dear all,
I am working on simulating the motion of a leaflet by applying a rigid body motion by means of the DEFINE_CG_MOTION macro.
I wrote a UDF for the movement; I compiled it and tested it in Fluent version 15.0 and it was perfectly reproducing what it was meant to do.
Then, last week I had to upgrade the software and I had version 17.1 installed. When I compiled the UDF this time the motion is completely incorrect although I have used the same structure of the code.
I have searched into the manual and compared the sections regarding the explanation of the macro. It seems that in the new version the software can call multiple times the UDF and that might lead to failure or incorrect updates of the velocity. I checked the example in the manual but I did not really understand it.
Can anybody help me? I also upload the code that I wrote so that you can have a better idea of what I am doing. I really need some suggestions to integrate this concept in the code.
Thank you in advance.
F.
Faggio11 is offline   Reply With Quote
Old   February 6, 2017, 10:55
pakk will become famous soon enough
I don't know what caused your problem.
But still, I could see some cleaning-up to do in your code to make it simpler. And simpler usually means that there are fewer places to make mistakes.
#include "udf.h"
#include <math.h>
#include <float.h>
float quadratic(a,b,c,time) {
    return (a*time*time+b*time+c);
DEFINE_CG_MOTION(leaflet_1, dt, vel, omega, time, dtime)
    real omega_1, omega_2, omega_3, ang_vel;
    const float tau = 0.866;
    const float timefrac=time/tau-(int)(time/tau); /* time = (i-1+timefrac) * tau ;  time-(i-1)*tau = timefrac * tau  */
    float a,b,c;
    NV_S(vel, =, 0.0);
    NV_S(omega, =, 0.0);
    if (timefrac < 0.005773672055427) /*interval 1*/
        a=2159.567580764660; b=-2.407990408052271; c=-0.011976420486241;
    } else if (timefrac < 0.011547344110855) /*interval 2*/
        a=-9353.043658991941; b=112.7181219895138; c=-0.299791701480157;
    } else if (timefrac < 0.017321016166282)) /*interval 3*/
        a=35252.60705520311; b=-779.3948922943873; c=4.160773369939347;
    } else if (timefrac < 0.023094688221709) /*interval 4*/
    } else if (timefrac < 1) /*interval 39*/
        a=-85.400423181754974; b=145.5055425427474; c=-61.973216494809272;
    omega_1 =  quadratic(a,b,c,timefrac*tau);
    omega_2 =  quadratic(a,b,c,timefrac*tau+dtime);
    omega_3 =  quadratic(a,b,c,timefrac*tau+dtime/2);
    omega[0] = (omega_1+omega_2+4*omega_3)/6;
I left out intervals 4 to 38 in the middle of the code, because they were boring.
pakk is offline   Reply With Quote
Old   February 6, 2017, 12:23
Giorgio
Dear pakk,
thank you for your quick reply. I really liked the way you coded it. It is simpler and smoother and it was totally understandable.
Unfortunately when I tried this new version in Fluent, it does not solve the problem. Actually, the motion becomes even more chaotic.
I do not think it is a problem of the code because I have just written a similar function in matlab (since I am much more familiar with it rather than C language) keeping the same structure and it perfectly reproduces the behaviour of the angular velocity (a picture in the attachment).
Do you have in mind any other suggestions?
Old   February 7, 2017, 04:46
I think you just messed up with the numbers.
If I used your numbers, I sort of see your graph, but with a lot of distortions, especially for t>0.3.
You are putting in numbers for chaotic motion, so Fluent will give that to you!
Your interpolation is a bit unusual.
You use omega = a*t^2 + b*t + c on each interval.
But to get nicer numbers a, b and c, you could use omega = a*(t-t0)^2+b*(t-t0)+c, where t0 is the start of the interval.
Old   February 10, 2017, 09:12
saurabh kumar gupta
rsaurabh is on a distinguished road
i am doing a simulation where blade will rotate. i have defined a udf but it is not compiling. it will be great if you look at it.
#include "udf.h"
#include "math.h"
DEFINE_SDOF_PROPERTIES(Valve_6dof, prop, dt, time, dtime)
prop[SDOF_MASS] = 0.01467375;
prop[SDOF_IZZ] = 0.00000000008995543548;
prop[SDOF_IXX] = 0.00000000002266435548;
prop[SDOF_IYY] = 0.00000000006729108;
prop[SDOF_ZERO_TRANS_X] = TRUE;
prop[SDOF_ZERO_TRANS_Y] = TRUE;
prop[SDOF_ZERO_TRANS_Z] = TRUE;
prop[SDOF_ZERO_ROT_X] = TRUE;
prop[SDOF_ZERO_ROT_Y] = TRUE;
prop[SDOF_ZERO_ROT_Z] = FALSE;
Message("\n2d : Updated 6DOF properties ");
rsaurabh is offline   Reply With Quote
Old   February 10, 2017, 11:45
Giorgio
Dear rsaurabh,
first of all, I would like to point out that your question is not really related to this thread.
Nevertheless, you should change the second line of your code: it is #include <math.h> and not with inverted commas.
Old   February 10, 2017, 14:13
Originally Posted by rsaurabh View Post
It would help if you could add the error message shown when you try to compile.
Problem in compiling fluent UDF lunched from MATLAB cfdman10 Fluent UDF and Scheme Programming 16 December 5, 2019 05:32
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 02:48
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
how to put udf inlet velocity and udf outlet pressure in fluent raminostadi Fluent UDF and Scheme Programming 4 July 3, 2017 06:43
Compiling UDF in Fluent 12 jsm FLUENT 1 July 22, 2009 07:40
