how to generate general wall function
Old   February 27, 2017, 00:48
Default how to generate general wall function
Neda S. R. Nikou
nedanikou is on a distinguished road
Hi every body
I have written a 3D Incompressible NS solver including k-e, Smagorinsky models to simulate turbulent flow in different test cases. I do not know how to generate general code for the wall function part which is applicable for any test cases. I have problem with corners and walls. of course, developed code was solved for the the flow in duct and pipe, dambreak. but each have different wall function part and is not applicable for any test cases. I would be grateful if you could help me.
nedanikou is offline   Reply With Quote
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 07:15
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 00:04
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
