Update Dynamic mesh failed- Negative cell volume detected
Old   April 24, 2017, 08:57
Default Update Dynamic mesh failed- Negative cell volume detected
kywong5 is on a distinguished road
Dear all,
Good evening. I'm trying to move a cube box (0.2m x 0.2 m x 0.2m) in a domain (1m x 1m x 1m). The movement distance will be 0.2m in x direction (Origin 0.5, 0, 0.5). I'm seeking for your kind opinion in solving this error:
Update-Dynamic-Mesh failed. Negative cell volume detected.
1) Tetrahedral mesh- No issue, I can obtain the result.
2) Hexahedral/ cut cell mesh- Update-Dynamic-Mesh failed. ((i) Using layering method-failed, (ii) using smoothing with Laplace method- failed)
Im using Fluent 14.
Thank you.
kywong5 is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
negative cell volume detected in dynamic meshing engrmansoor2534 FLUENT 0 November 6, 2015 10:34
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
