Put a Dynamic Mesh MACRO in DEFINE_EXECUTE_AT_END MACRO in ANSYS FLUENT ?
Old   September 11, 2017, 09:36
Default Put a Dynamic Mesh MACRO in DEFINE_EXECUTE_AT_END MACRO in ANSYS FLUENT ?
Haryana
Sj5n13 is on a distinguished road
I want to Sense RPM of a wind turbine blade after every time step and for this I have written a UDF as follows:
#include "udf.h"
DEFINE_EXECUTE_AT_END(rpm_sensing)
int zone_ID = 7;
Domain *domain;
domain = Get_Domain(1);
Dynamic_Thread *dt;
Thread *t = Lookup_Thread(domain,zone_ID);
face_t *f;
t = DT_THREAD(dt);
real omega;
real rpm;
omega = NV_MAG(DT_OMEGA_CG(dt));
rpm = (omega*60)/(2*3.14);
but whenever I compile it, it gives me a warning: warning C4700: uninitialized local variable 'dt' used.
My question is, how can I assign a Thread to be a Dynamic Thread? If that is not possible how should I go about sensing the angular velocity of the whole thread at every timestep?
Sj5n13 is offline   Reply With Quote
Old   September 13, 2017, 11:31
Cees Haringa
CeesH is on a distinguished road
can't answer your question, but a certain problem is that you did not assign dt.
you did:
for a regular thread, but not for dt.
CeesH is offline   Reply With Quote
ansys, fluent - udf
Ansys Fluent Mesh to be Used in Mechanical Thermal System jjlt ANSYS 0 January 26, 2017 01:50
error in ansys fluent while solving dynamic mesh problem of moving wall classified FLUENT 3 November 23, 2016 01:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 22:56
