UDF for Rotating blades
Old   October 6, 2017, 05:48
Default UDF for Rotating blades
andrew97 is on a distinguished road
Hi, I'm new to the entire concept of UDFs and was wondering if there were any good materials out there on how to define them, particularly ones involving rotating rigid bodies around an axis and where the speed of rotation is linked to the flow i.e. lift produced by the body?
I hope that makes sense, thanks.
andrew97 is offline   Reply With Quote
Old   October 9, 2017, 15:38
obscureed is on a distinguished road
Oof! Have a look at Dynamic Mesh, and in particular "Six DOF". This might involve UDFs in the end, but hopefully very simple ones (like, 4 lines long) if at all. It does not sound easy, though.
obscureed is offline   Reply With Quote
Old   October 9, 2017, 16:51
I managed to figure it out using that method, i think, didn't even need the UDF. Thanks.
Though on a UDF sidenote, do you know how to vary inlet velocity using a UDF?
Old   October 11, 2017, 07:31
For the benefit of posterity, please could you sketch out the method you used for the rotation?
On the sidenote: for varying inlet velocity (as a function of time, position, etc), see DEFINE_PROFILE in the Fluent Customization Manual.
Old   October 15, 2017, 14:10
It seems like I was incorrect and I can't recreate what the results I got earlier.
Thanks for the help
Edit: Nope, wrong again haha. If you follow Raef Kobeissi's 6DOF turbine tutorial you'll be fine. I just overestimated the moment of inertia for my blades and so it couldn't turn.
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 02:30
udf for multiple reaction alihosseini63 Fluent UDF and Scheme Programming 0 July 4, 2013 18:37
UDF programming fullmonty FLUENT 5 June 30, 2011 02:40
DEFINE_GEOM UDF Problems Pat FLUENT 0 August 14, 2003 13:16
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
