Unsteady boundary condition UDF for parallel FLUENT
Like Tree4Likes
  • 1 Post By kirmaks
  • 1 Post By pakk
  • 2 Post By obscureed
Old   October 13, 2017, 11:22
Default Unsteady boundary condition UDF for parallel FLUENT
Hong M.H is on a distinguished road
Hello guys, currently i m doing a research on synthetic jet, and i have to use UDF to define the my unsteady oscillating inlet boundary.However, for the previous case i used serial and now i have to use parallel in order to speed up my progress. Thus, i have been modifying my previous UDF coding from serial to parallel according to my own understanding from fluent manual. I would like to ask is my coding right? the coding has been attached as below:
#include "udf.h"
DEFINE_PROFILE(unsteady_z_velocity, thread, position)
#if PARALLEL
real t = CURRENT_TIME;
float v;
face_t f;
begin_f_loop(f, thread)
if (PRINCIPAL_FACE_P(f, thread))
F_PROFILE(f, thread, position) = v;
v = 0.41*sin(3141.5927*t);
end_f_loop(f, thread)
#if RP_NODE
v= PRF_GRSUM1(v);
# endif
#endif
Your help is much appreciated, Thank you.
Hong M.H is offline   Reply With Quote
Old   October 16, 2017, 07:07
KirMaks
kirmaks is on a distinguished road
Hallo,
I think Your UDF has no parts which are dependent on which version of FLUENT (serial or parallel) is used. You may try to check if this code works:
#include "udf.h"
float v;
face_t f;
Regards, Maksim
Hong M.H likes this.
kirmaks is offline   Reply With Quote
Old   October 16, 2017, 08:10
pakk will become famous soon enough
#include "udf.h"
#if PARALLEL
float v;
face_t f;
#if RP_NODE
v= PRF_GRSUM1(v);
# endif
#endif
The easiest way to test if this parallel code gives the same results as your serial version: run it, and compare results!
pakk is offline   Reply With Quote
Old   October 17, 2017, 02:13
Thank you for ur suggestion, Maksim...ur help is much appreciated!
Old   October 17, 2017, 02:16
Originally Posted by kirmaks View Post
Hallo,
#include "udf.h"
float v;
face_t f;
Regards, Maksim
Thank you for ur suggestion Maksim!
Thank you for ur suggestion pak!
Old   October 17, 2017, 07:21
obscureed is on a distinguished road
I agree with the other comments. I would even go further than Pakk's comment: you would like to have one UDF that gives the same results in parallel and in serial. (That is, you should not try to maintain/compare a serial version and a parallel version of the same code. The UDF you presented, with all the code wrapped in "#if parallel ... #endif" fails this.)
Some minor points, mostly just programming style but with some definite benefits:
1) Since the velocity is the same for all faces, you can do the "v=..." once, before the face loop. This will be quicker.
2) I think there is no harm in applying the boundary condition to the "external" copies of faces. So, in this situation, you do not need the test "if(PRINCIPAL_FACE_P(...". But it is good to get into the habit of thinking about these side cases for parallel UDFs.
3) Why do you have "t" as a real and "v" as a float? (Just as a reminder: float in the built-in C single-precision type; real varies in Fluent UDFs according to whether Fluent is run in single- or double-precision.) A good general policy in Fluent UDFs is never to use float, and almost always use real. The occasions when you don't use real are when you want to force the UDF to use double precision -- and this might be one of those rare occasions. CURRENT_TIME returns a double (as you can guess from looking at flow.h header file).
4) It would make the code easier to read and to maintain if you defined the frequency as a preprocessor macro. This avoids the need to memorise pi, and the risk of forgetting the factor of 2. UDFs (and C) have the macro M_PI.
5) Once you have followed point 4, you can easily print out the current values of the parameters. This is reassuring, and gives you a chance of detecting any slip-up if you intend to change the values. On the other hand, printing every time the profile is called might be excessive, so you could devise some way to print less often -- I've given an example (but not compiled to test it).
Something like this:
#define PEAK_VELOCITY_IN_METRES_PER_SEC 0.41
#define FREQUENCY_IN_REVS_PER_SEC 500.
#define PRINTS_PER_PERIOD 4.
static real next_print_time = 0.;
   double t = CURRENT_TIME;
   real v;
   face_t f;
   v = PEAK_VELOCITY_IN_METRES_PER_SEC *
      sin(FREQUENCY_IN_REVS_PER_SEC*2.0*M_PI*t);
   begin_f_loop(f, thread){
   }end_f_loop(f, thread)
   if(t >= next_print_time) {
      Message0("With vmax=%g m/s, freq.=%g rev/s: time=%g, v=%g\n",
         PEAK_VELOCITY_IN_METRES_PER_SEC,
         FREQUENCY_IN_REVS_PER_SEC,
         t,v);
      next_print_time += 1./(FREQUENCY_IN_REVS_PER_SEC *
         PRINTS_PER_PERIOD);
pakk and Hong M.H like this.
obscureed is offline   Reply With Quote
Old   October 18, 2017, 21:01
Thank you for your advises, obscureed. your comments are useful for beginners like me,i wish that i could learn more from u
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 05:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
UDF fluent:Change boundary condition. determination inlet and outlet boundary in "t" gzamiri@gmail.com FLUENT 0 September 27, 2015 05:32
