Query relating to scheme programming
Old   October 17, 2020, 09:05
Default Query relating to scheme programming
Madhu Kalyan
Madhu Kalyan is on a distinguished road
I have been working with ANSYS (Fluent and CFX) for a little more than a couple of years now, and right now I am working on a problem that can be done using periodic conditions. I am currently using ANSYS 2020 R1 and I can set the zones I need to translational periodicity. My queries are as follows:
1. How can I parametrize the mass flow rate condition as the input parameter and the pressure gradient as the output parameter? I have read in some online forums that I have to code it in. If so, How can I do that, and is there any non-coding procedure to achieve the parameterization?
2. I know that having a convergence of 10^-6 is the best but in case I am unable to achieve it then what should be the optimal route. I have conducted grid independence for my model with a low mass flow rate and that optimal mesh is actually failing to converge when I go for a little higher mass flow rate. I do try and change the "pressure" and "momentum" in the "controls" menu and I do get slightly better residuals but not being able to achieve the 10^-6 and it kind of flatlines around the 10^-4 mark. What should be done according to you?
3. What do the GPGPUs for the parallel computation before entering the fluent solver actually mean. I do have a 4 GB NVIDIA graphic card and I did read a little about involving the GPU for simulations by using a 3rd party software in earlier versions. Do the 3rd party ones still hold good or can I directly give the number of cores?
Madhu Kalyan is offline   Reply With Quote
convergence, fluent, gpu processing, scheme programming
Error: Out of scheme heap space SSG_NJ FLUENT 2 July 24, 2021 06:31
Looping a journal in Scheme programming Arvind_CFD Fluent UDF and Scheme Programming 1 October 11, 2014 11:00
Scheme Programming in Fluent James Nally FLUENT 1 April 25, 2008 12:39
scheme programming abdellah FLUENT 2 June 14, 2005 04:20
scheme programming in Fluent Wenbin FLUENT 2 November 27, 2003 13:49
