April 4, 2018, 19:16 |
Diffusivity UDF in Fluent
Max
Rep Power: 8 |
I am using the Eulerian multiphase model to simulate particle flow in water. I am attempting to hook a diffusivity UDF to the mixture (code includes diffusion of the particle into the water). However, I seem to have some misunderstanding as to the setup. I have selected for there to be one User-Defined Scalar. Next, I am compiling my UDF and loading into fluent. After that, I open up Create/Edit Materials panel and go to the UDS Diffusivity section. I am then selecting 'User-Defined' and attaching the UDF that I compiled. After running my simulation, it seems that the UDF is not applied correctly. My UDS-0, which will hopefully track the diffusion of particles, just has a residual and value of zero, so I know that I am doing something incorrectly in this process. Does anyone know what I am doing wrong in my setup, such that my code is not actually being applied? This is my first time using a UDF, so any help would be greatly appreciated! |
fluent, user defined function, user defined scalar |
A Problem of Fluent Interpreted UDF: parse error | knight | Fluent UDF and Scheme Programming | 25 | August 16, 2018 10:26 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
UDF diffusivity: problem with contour | Lilly | Fluent UDF and Scheme Programming | 0 | August 4, 2014 03:28 |
Fluent UDF for thermal NOx | larsschwarzer | Fluent UDF and Scheme Programming | 1 | July 18, 2014 08:39 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 10:16 |
