February 12, 2013, 09:50 |
UDF temperature profile
Astio Lamar
Rep Power: 14 |
Hello every body.
I have a geometry with inlet dimension of z=1.2 and y=2.46 at the inlet. I want to define an inlet temperature profile at the inlet using UDF. the temperature varies along the y coordinate. #include "udf.h" DEFINE_PROFILE(inlet_x_temperature, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = ...; } end_f_loop(f, thread) } But I got error. "floating point exception" this is simple sketch of the geometry: I think something with the coordinate should be the problem. could any body help me? Moreover I read somewhere that it is possible to define the boundary with the coordinated. for instance I have two array y = [0.2 0.4 ... 2.4] t = [21 15 ... 18] then I can define a temperature inlet profile based on the y coordinate and temperature array. Any idea? thanks. Last edited by asal; February 13, 2013 at 09:07. |
February 12, 2013, 10:28 |
Alex
Rep Power: 46 |
Which formula describes your function? Without knowing what you put instead of the "..." in
F_PROFILE(f, thread, position) = ...; no one can guess what is causing the error. |
February 12, 2013, 10:47 |
Astio Lamar
Rep Power: 14 |
Sorry.
I think it is not important!! F_PROFILE(f, thread, position) = 19.59+0.532*y+0.36*y*y-0.157*y*y*y; |
February 12, 2013, 10:55 |
Alex
Rep Power: 46 |
Wait a minute: When does the error occur?
When you try to interpret/compile your UDF or during the solution process? What are the possible values y can have, i.e. what is the physical extent of the boundary? |
February 12, 2013, 11:30 |
Astio Lamar
Rep Power: 14 |
I got error at the beginning of simulation process, no error for interpret/compile.
y values start from zero to 2.46 (the y dimension of the geometry). I have a data array for y and temperature as below: y = [0.2 0.4 0.6 ... 2.2 2.4] temp = [19 20 20.4 .... 19.54 20] So the UDF should specify this temperature profile at the inlet varied in y direction. see the above figure. |
February 12, 2013, 11:46 |
Alex
Rep Power: 46 |
I guess that the problem arises from the °C/K difference.
Fluent expects the output of UDFs to be in SI-Units. Therefore, the output of the UDF is interpreted as a Temperature between 21 and 23 K. This might be inconsistent with the initial values you provide, causing the solution to diverge. For the definition of BCs via arrays: Fluent can read (and write) profiles for boundary conditions. The easiest way to get familiar with is is to write such a profile at the boundary condition of interest. From the file created, you can derive the necessary file format to provide profile data. |
February 13, 2013, 09:13 |
Astio Lamar
Rep Power: 14 |
Hello and thanks a lot for your helpful hint.
I change my equation to SI-Units and everything done. just few questions: could you please briefly describe what theses lines means. real x[ND_ND]; /* this will hold the position vector */ what "this will hold the position vector" exactly mean? also real y; face_t f; F_CENTROID(x,f,thread); y = x[1]; for instance y = x[1]; if I change it to y = x[0]; then what is going on? if my temperature varies along the Z or X coordinate, then how should I change the code? I am quite familiar with C programming. I understand the loop. just I have problem with the coordinated and so on. thanks. |
February 13, 2013, 10:36 |
Alex
Rep Power: 46 |
Glad I could help.
Lets take a look at your further questions. x[ND_ND] is an array of dimension 2 if you are running the 2D solver and dimension 3 if you are running the 3D solver (which is obviously the case). Accordingly, x[0] corresponds to the x-position, x[1] is the y position and x[2] is the z position. Now the comment "this will hold the position vector" should become clear. with "real y" you define a variable of type real with the name y. Usual syntax... face_t f : same thing, f appears in the loop arguments. The exact definition can be found in the UDF manual. F_CENTROID(x,f,thread); Here you evaluate the position of the face centroid and assign it to the variable x. y=x[1]; This step is a bit redundant. You might aswell use x[1] in the following equation directly. It just makes the equation look better and maybe saves some computing time. |
February 14, 2013, 06:39 |
#9 |
Astio Lamar
Rep Power: 14 |
Hello again and thanks for your helpful answer.
Just one more questions. How can I use two profile simultaneously? when I add the second one, then the first is vanished and I cannot use it anymore in the boundary setting! For instance I want to use both velocity and temperature profile at the inlet at the same time. first I have interpreted the velocity and then, when I interpreted the temperature profile, then the first one in not available in the boundary setting to select. what should I do? thanks. |
February 14, 2013, 06:55 |
#10 |
Alex
Rep Power: 46 |
Did you try to put both UDFs in one text file?
Then when interpreting the file, both UDFs should be available. |
February 14, 2013, 07:02 |
#11 |
Astio Lamar
Rep Power: 14 |
Great!
It works. thank you so much. |
July 23, 2013, 08:31 |
#12 |
sooraj
Rep Power: 13 |
hi
i need a udf for a project work. I'm quite new to this area and have a very short time frame for completing this work. so i really need your help. I need a linearly varying temperature profile boundary condition to be applied on the circular face of a cylinder.temperature varies from 25 to 50 degrees from bottom to top. diameter of circle is 470 mm . Can you help me??? |
July 23, 2013, 08:40 |
#13 |
Alex
Rep Power: 46 |
"Linearly varying" with respect to which variable?
Could you make a small sketch of what you need? |
July 23, 2013, 09:18 |
#14 |
sooraj
Rep Power: 13 |
thanx for replying . consider a horizontal cylinder. on one of its circular faces i need this temperature variation from bottom to top.
July 23, 2013, 09:42 |
#15 |
Alex
Rep Power: 46 |
Since you refuse to be more descriptive, I have to make some assumptions
With "degrees" you mean °C, so I change the temperature variation from 298K-323K. The x-axis coincides with the axis of the cylinder and the y-axis is from "bottom" to "top". Thus the temperature varies linearly with the y-axis, with the highest temperature at the greatest positive y-extent of the surface. Code:
#include "udf.h" DEFINE_PROFILE(temp_linear, thread, position) { real x[ND_ND]; face_t f; real tmin, tmax, d; tmin = 298.0; tmax = 323.0; d = 0.47; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); F_PROFILE(f, thread, position) = (tmin+tmax)/2.0 + (tmax-tmin)/d*x[1]; } end_f_loop(f, thread) } |
July 23, 2013, 14:21 |
#16 |
sooraj
Rep Power: 13 |
have you seen the image i attached ?? i'm not sure if it is visible or not . else please tell me i will upload another one.
July 23, 2013, 14:26 |
#17 |
Alex
Rep Power: 46 |
I dont see an image attached to your post.
July 24, 2013, 00:42 |
#18 |
sooraj
Rep Power: 13 |
i'm uploading it again. thanx for your help
July 24, 2013, 03:04 |
#19 |
Alex
Rep Power: 46 |
Without a coordinate system, this image doesnt add much information.
Did you at least try the UDF i proposed 4 posts ago? Just change x[1] if the y-axis is not the direction in which the temperature rises. |
July 24, 2013, 05:35 |
#20 |
sooraj
Rep Power: 13 |
sorry for not mentioning the coordinates. axis of the cylinder is in z direction and temperature rise is in y direction .Does that change anything in the code?? i tried the given code and it runs without any problem. Also may i know your real name so that i can give you credits in the report i'm going to make??
please help UDF for velocity profile in y-directio | raju | Fluent UDF and Scheme Programming | 6 | April 12, 2019 23:21 |
UDF error - parabolic velocity profile - 3D turbine | Zaqie | Fluent UDF and Scheme Programming | 9 | June 25, 2016 19:08 |
defining temperature profile with UDF | mohammadkm | Fluent UDF and Scheme Programming | 11 | July 3, 2013 00:15 |
UDF temp. profile BC | Shashikant | FLUENT | 0 | June 24, 2006 03:16 |
temperature profile on boundary | sivakumar | FLUENT | 5 | November 24, 2002 00:58 |
