UDF received a fatal signal(segmentation fault)
Old   September 28, 2018, 09:13
Default UDF received a fatal signal(segmentation fault)
Li Xiaoying
Lxy2018 is on a distinguished road
Hi!
I successfully compiled a UDF about DPM using "Transient Calculation". During the calculation:
the error appeared as shown below:
Error: received a fatal signal(segmentation fault)
Error object:#f
I checked the code and I think it's right.
who can help me? Thanks!
Lxy2018 is offline   Reply With Quote
Old   September 28, 2018, 10:17
Cees Haringa
CeesH is on a distinguished road
Difficult without the code. But generally, a segmentation fault means that FLUENT is looking for something in the memory that is not there. IT could be unintialized, it could be a wrong thread reference (are you running multiphase? Make sure you are pointing to the right phase threat), it could be an unassigned UDM
CeesH is offline   Reply With Quote
Error: received a fatal signal (Segmentation fault). Error Object: #f Naveen Kumar Gulla FLUENT 0 May 18, 2018 14:12
fatal signal segmentation fault in a UDF hares FLUENT 6 January 21, 2017 03:26
Erron: FLUENT received fatal signal (ACCESS_VIOLATION) in DPM Heat and Mass Transfer Melvin FLUENT 2 November 17, 2016 01:06
FLUENT received fatal signal (ACCESS_VIOLATION) Error jreiter164 Fluent UDF and Scheme Programming 3 February 16, 2015 13:19
Fluent received fatal signal (ACCESS_VIOLATION) sravan451 Fluent UDF and Scheme Programming 5 May 10, 2011 23:37
