UDF-Fluent debug on Ubuntu.
Old   November 26, 2018, 03:48
Default UDF-Fluent debug on Ubuntu.
pianaCFD is on a distinguished road
Good morning,
I'm working with Ansys Fluent and the UDFs on Ubuntu. Is there an efficient way to debug a code?
I've already tried those two guides:
1) https://www.cfd-online.com/Wiki/Udf_debug
The point is that I can't debug my code efficiently or maybe I just don't know how to do it. For example when Fluent is giving me a segmentation fault, the gdb from terminal is just showing me 'segmentation fault' as you can see in the attachment below. So, I can't see which variable has problems. Moreover, is there a useful meaning on the number 0x00007fdada76afb7 that you can also see in the attachment?
2) [UDF compiling/debug]an integrated tool to edit/compile/debug UDF in Visual Studio
Is this tool also working on Ubuntu? I've installed it with Wine, but it seems like I can't charge my VC version and my Fluent version to run on Ubuntu.
Is there a way to debug an UDF that shows also where is the problem? Or is there a way to show where is the problem following the previous guides?
Thank you for any help.
pianaCFD is offline   Reply With Quote
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
fluent UDF external library lapack problem Rick FLUENT 0 May 7, 2008 10:16
UDF problem caused by various version of Fluent Yurong FLUENT 3 January 15, 2006 10:57
