error: Received signal SIGSEGV
Old   November 28, 2018, 07:52
Default error: Received signal SIGSEGV
giovanni ianziti
ianziti92 is on a distinguished road
Hi everyone !
I`m working with this UDF for describing mass transfer, between water and vapour, and the energy exchange. I`ve read the mass transfer (of udf) in the phase interaction window, after I've read the energy source in the cell fluid zone. Now i can`t initialize mi simulation because appear these errors. Can you help me please? thank you
Node 0: Process 7960: Received signal SIGSEGV.
Node 1: Process 18492: Received signal SIGSEGV.
Node 2: Process 3692: Received signal SIGSEGV.
Node 3: Process 12992: Received signal SIGSEGV.
Node 4: Process 17000: Received signal SIGSEGV.
Node 5: Process 8368: Received signal SIGSEGV.
Node 6: Process 1856: Received signal SIGSEGV.
999999: mpt_accept: error: accept failed: No such file or directory
ianziti92 is offline   Reply With Quote
Old   December 5, 2018, 15:57
Sanket Dange
sanketdange2007 is on a distinguished road
This error SIGSEGV means segmentation fault or access violation.
In simple words you are trying to access some variable or pointer which was deleted
from memory.
Are you reading any file from UDF ?
Are you using any gradient variable like C_T_G in your UDF?
sanketdange2007 is offline   Reply With Quote
Old   December 5, 2018, 16:25
giovanni ianziti
Yes I'm trying to recreate the Lee model with UDF. How can I solve this problem? I attach the first part of the UDF
Thank you
error 999999, signal sigsegv, udf
Node 0: Process 15088: Received signal SIGSEGV. hasib61 FLUENT 7 September 4, 2022 01:25
[ImmersedBoundary] About the moving immersed boundary tutorial: icoDyMIbFoam+movingCylinderInChannelIco wyldckat OpenFOAM Community Contributions 25 September 14, 2021 17:15
rhoSimpleFoam time step continuity errors deepbandivadekar OpenFOAM Running, Solving & CFD 2 September 13, 2018 05:50
define_wall_functions density and dynamic viscosity Ionut G Fluent UDF and Scheme Programming 3 March 15, 2017 10:10
[ICEM] "Tgrid received signal SIGSEGV (Segmenetation Violation)" hasanifte ANSYS Meshing & Geometry 0 April 1, 2015 18:10
