over predicting at inlet with k omega SST
Old   November 19, 2018, 15:51
Default over predicting at inlet with k omega SST
mehran mohammadi
mehran.mo is on a distinguished road
hello there
I'm trying to do an internal flow computation. my geom is a simple pipe that flow inter from one side and go out from another side (geom was attached bellow) I'm using k omega SST model in fluent . and there is my other condition:
my solver is steady pressure based, Yplus<1 , using a coupled scheme for pressure velocity coupling (courant number is set to 20) and ideal gas as a fluid . i used mass flow and inlet velocity would arrived to 120m/s therefore i set operating pressure to 0 and use a total pressure at inlet(115000pa) and outlet(110000pa). my wall temperature is 500k and inlet temperature is 350 . i used pressure outlet for outlet boundary and .
my mesh condition is :
i used o grade and
quality : 0.7
max skew : 0.25
max aspect : 98
and there is my NU contour was attached bellow my solve is converged to 1e-05 but i have an over prediction at inlet i dont know why?? could anyone help me please?
p s : if i use course mesh at wall and use a wall function i wouldn't have this problem but because of some reason i should do it with k omega
thank for any hints
mehran.mo is offline   Reply With Quote
fluent, k omega, k omega sst, massflow bc, overpredicting
Behaviour of the kOmegaSST in a steady-state case Max1234 OpenFOAM Running, Solving & CFD 18 October 31, 2018 08:03
Hoz to fix Y+ dependence on inlet Mach number? SST turbulence model LuReym CFX 5 January 20, 2015 16:28
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 13:06
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 18:42
