Dynamic mesh using UDF and layering method - no dynamic mesh zones to display error |
January 15, 2019, 18:30 |
Hootan
I am running a 2D Cylinder and Piston on Fluent and I want to use the layering method in dynamic mesh while I use a UDF for piston motion. The first question is literally how can I do this?! I tried to define dynamic mesh zones but when I click on the display zone motion, unfortunately, I get the no dynamic mesh zones to display. I define the piston as a rigid body with a UDF and other zones as stationary. Would you please help me to get this moving? |
May 7, 2019, 04:32 |
Randal Wang
Rep Power: 7 |
Hi Hootan,
Have you solved this problem? I am facing a similar question with you. |
May 7, 2019, 10:41 |
#3 | |
Hootan
Yes, I have solved this. You need to first define your moving object as a rigid body and then define the environment in which your object is moving as deforming. There are some zone parameters that need to be defined in the dynamic mesh menu, which is based on your mesh size. Also, I used the layering method so it is necessary to make sure other methods are off in the methods menu. |
May 7, 2019, 12:03 |
#4 | |
Randal Wang
Rep Power: 7 |
Thanks a lot for your kind reply! I described my question with some pictures in another Thread. Here is the link: Fluid Damper Simulation Could you give me some advice? |
dynamic mesh, dynamic mesh zones, udf, udf compile |
Dynamic mesh & Negative volume in 3D | mahzironrazak | FLUENT | 97 | December 28, 2020 22:09 |
Dynamic mesh update problem. | David | FLUENT | 3 | March 15, 2012 05:02 |
Dynamic Mesh UDF | Jkl | FLUENT | 9 | September 6, 2011 23:43 |
Dynamic Mesh moving interface help | akash.iitb | FLUENT | 0 | August 23, 2010 23:53 |
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! | alban | Fluent UDF and Scheme Programming | 2 | June 8, 2010 18:54 |
