UDFs run three times instead of just once
Old   January 25, 2019, 10:34
Unhappy [SOLVED] UDFs are run three times instead of just once
nvx
nvx is on a distinguished road
Perhaps someone here will be able to help me with the following problem: even with a rather minimal UDF (see further), the included functions are always run three times instead of just once. For example, when I compile this source file:
#include "udf.h"
DEFINE_EXECUTE_ON_LOADING(on_loading, libname)
    Message("\n%s has been loaded.\n", libname);
DEFINE_EXECUTE_AT_END(fcn)
    Message("\n(Computing additional stuff)\n");
(obviously without any errors) and try to load it, it seems to be loaded three times -- see the three occurrences of "libudf has been loaded." in the log below:
make[3]: Leaving directory `/home/xxx/test/libudf/lnamd64/3ddp_node'
make[2]: Leaving directory `/home/xxx/test/libudf/lnamd64/3ddp_node'
make[1]: Leaving directory `/home/xxx/test/libudf/lnamd64/3ddp_node'
Opening library "/home/xxx/test/libudf"...
Library "/home/xxx/test/libudf/lnamd64/3ddp_host/libudf.so" opened
Library "/home/xxx/test/libudf/lnamd64/3ddp_node/libudf.so" opened
	on_loading
	fcn
UDF Autorun:
on_loading
Done.
Similarly, when I set the function "fcn" to be run at the end of iteration/time step via function hooks and run the simulation, the log looks like this:
  iter  continuity  x-velocity  y-velocity  z-velocity      energy           k     epsilon     time/iter
!  104 solution is converged
   104  9.1032e-04  4.3001e-04  1.7156e-04  1.2367e-04  1.4684e-16  7.1970e-04  9.9163e-04  0:00:00 200
!  105 solution is converged
   105  9.1246e-04  4.1374e-04  1.6847e-04  1.2057e-04  1.4959e-16  6.9600e-04  9.7084e-04  0:01:03 199
Calculation complete.
Again, the message from the respective function ("(Computing additional stuff)") is shown three times. I have no clue why this could be happening...
Just for completeness' sake: I am using Fluent 19.1 on a linux machine.
Any help would be much appreciated.
nvx
EDIT (27 Jan):
Today I also tried to replicate the issue in a freshly-installed virtual machine (CentOS 7 x64). The result was identical to what I have been experiencing with the other linux machine. In other words, with the same minimal source code mentioned above, UDFs from the compiled library were always run three times.
nvx is offline   Reply With Quote
Old   January 27, 2019, 06:33
pakk will become famous soon enough
Could it be that you are running parallel with three nodes?
pakk is offline   Reply With Quote
Old   January 27, 2019, 06:40
nvx
pakk,
Thank you for your response, it led me to the solution! After a lot of additional digging and testing it seems that Fluent runs both types of UDFs mentioned in the example on all compute nodes, i.e., including the master node. This was what confused me all along, because the number of UDF executions did not even match the number of specified parallel nodes...
nvx
Problem with foam-extend 4.0 ggi parallel run Metikurke OpenFOAM Running, Solving & CFD 1 December 6, 2018 15:51
Long loading times and unable to run with 4 cores in ANSYS AIM Vestdam ANSYS 0 October 4, 2018 03:10
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 22:29
parallel run is slower than serial run (pimpleFoam) !!! mechy OpenFOAM 18 August 17, 2016 17:19
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 15:25
