Viscosity UDF Gives different Results to fluent Model?
Old   March 28, 2019, 07:52
Default Viscosity UDF Gives different Results to fluent Model?
Sebi
bloodflow is on a distinguished road
Hi All.
I am examining many different viscosity models through UDF's in Fluent. I have written a UDF for the Carreau model even though it is in Fluent. When I run 2 identical simulations, one using my UDF for Carreau Viscosity, the other using Fluents inbuilt model, they give different results. This is implying my UDF's are not working as intended, and are likely wrong for the other models. Is there a reaosn why this UDF doesnt implement the Carreau model? (both models use the same values for max/min shear visco, lambda and n.)
Could this be because of the rounding errors in my code? Would it be more accurate to use "double" instead of "float"?
/* Carreau (p=2) Viscosity Model */
#include "udf.h"
float muinf=0.00345;
float mu0=0.056;
float lambda=3.313;
float p=2;
float n=0.3568;
DEFINE_PROPERTY(cell_viscosity,c,t)
real diff;
real shear;
real prod;
real power;
real visco;
diff=(mu0-muinf);
prod=((lambda)*(C_STRAIN_RATE_MAG(c,t)));
shear=(1+(pow(prod,p)));
power=((n-1)/(p));
visco=((muinf)+(diff)*(pow(shear,power)));
return visco;
bloodflow is offline   Reply With Quote
Old   March 28, 2019, 20:11
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
why did you ask? try it. Change everything to real.
best regards
AlexanderZ is offline   Reply With Quote
carreau, fluent, udf, viscosity
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
How to solve UDF compilation problems in Fluent. pakk Fluent UDF and Scheme Programming 16 September 10, 2018 02:48
standard wall function UDF fluent (k-omega model) alinik Fluent UDF and Scheme Programming 0 April 27, 2017 18:05
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 10:29
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
