UDF - Error loading libudf
Like Tree56Likes
Old   March 2, 2011, 09:56
Default UDF - Error loading libudf
Atze is on a distinguished road
i've succesfully compiled my udf, but when i load it fluent says
The UDF library you are trying to load (libudf) is not compiled for 2ddp on the curent platform (win64).
what can i do ?
I use fluent 13, visual c++ 2008 express and win7 x64
Thank you
Atze is offline   Reply With Quote
Old   August 29, 2011, 02:53
Josy
Josyula is on a distinguished road
Were you able to sort out this problem?
If yes, kindly please let me know how you resolved this issue.
Thank you.
nasreddine likes this.
Josyula is offline   Reply With Quote
Old   August 29, 2011, 09:50
The_Architect is on a distinguished road
if you have not done it be sure to start Fluent from the VS command prompt.
The_Architect is offline   Reply With Quote
Old   August 29, 2011, 11:43
Hongjin Wang
sosososo1114 is on a distinguished road
HI, have you checked the environment settings of your computer? Make sure all the settings are correctly. I remember once there was a thread talking about how to set the computer environment for FLUENT on this forum, if you followed all the instructions in the replies above but you still could not get udf work, would you mind to search through the forums to find that thread, and reset the environment. This should work.
Best regards,
Hongjin
MDSHUJAN and nasreddine like this.
sosososo1114 is offline   Reply With Quote
Old   January 12, 2012, 04:22
Kiran
kiran_kumar is on a distinguished road
Could any body resolved this problem?
I have seen many threads regarding this but yet I am not able to solve the proble.
I have installed Visual studio 2010 express and Fluent 13. Also installed "Microsoft Windows SDK v7.0".
I have run the Fluent from SDK command prompt. And yet I have recieved the error saying that
"The UDF library you are trying to load (Sedimentation) is not compiled for 2ddp on the curent platform (win64).
The system cannot find the file specified.
C: estudf\Sedimentation\win64\2ddp\libudf.dll"
Please let me know the solution for this.
Thanks in advance.
KK
kiran_kumar is offline   Reply With Quote
Old   January 13, 2012, 09:50
Default Compiling and Loading 64 bits UDF library
laurentb's Avatar
Laurent B
laurentb is on a distinguished road
This ANSYS support note provides all informations necessary to compile UDF for FLUENT 64-bit
File Type: pdf 2020316-Compiling and Loading FLUENT 64 - using SDKx.pdf (94.9 KB, 7359 views)
laurentb is offline   Reply With Quote
Old   January 14, 2012, 02:11
Kiran
Hi Laurent ,
Thanks for the help.
Now it is working fine for me. I have followed same steps as mentioned in pdf file.
Probably this file is available for all the users of this forum.
KK
Old   February 2, 2012, 05:35
Cam
Cam
Cam is on a distinguished road
Hi Laurentb
I am having the same issue, I have read the PDF but do not understand,
I am a beginner and trying to complete the tutorial "heave and pitch simulation of ship hull moving through head sea waves" and I have the hull geometry and a 6DOF UDF which is what I cannot load as it says
"The UDF library you are trying to load (libudf) is not compiled for 3ddp on the curent platform (win64).
The system cannot find the file specified."
Can you please explain in simple terms what I need to do,
Thank you in advance!
Cameron
Cam is offline   Reply With Quote
Old   February 2, 2012, 05:45
Kiran
the content of the pdf file :
Compiling and Loading FLUENT 64-bit UDFs using the "FREE" Microsoft Visual Studio 2010 32-bit Express Edition and the 7.0 SDK
IMPORTANT SUPPORT NOTE
: The 2010 Express Edition and the SDK will allow you to compile 64-bit UDFs for FLUENT. However, the installation and use of the Express and the SDK is not “officially” supported so we ask that you get your IT folks involved in
the actual installation.
RESTRICTIONS
: Also, you CANNOT compile UDFs for FLUENT without first opening the SDK Command prompt window and starting FLUENT from this window.
Instructions
Download the Microsoft Visual Studio Express Edition (2010) performing a default installation
http://www.microsoft.com/express/Downloads/#2010-Visual-CPP. Search for the text: Microsoft Visual C++ 2010 Express in your browser window.
7.0 SDK
Microsoft Windows SDK for Windows 7 and .NET Framework 3.5 SP1
or search for the text: Microsoft Windows SDK for Windows 7 and .NET Framework 3.5 SP1 in your browser window.
IMPORTANT NOTE FROM MICROSOFT
: if you are running a 64-bit version of Windows and Visual Studio 2008, please upgrade to Visual Studio 2008 SP1 before installing the Windows 7 SDK. Search for the text: Microsoft Visual Studio 2008 Service Pack 2 in your browser window.
This prevents an issue where some platform configuration choices are unavailable in Visual Studio’s New Project Platform and New Solution Platform dialogs.
Starting FLUENT using the SDK 7.0 Command Prompt Window
1. Open up the SDK Command Window. This is required as this will set the compiler environment variables.
2. Choose the
Start Menu > All Programs > Microsoft Windows SDK v7.0 > CMD Shell
3. Launch FLUENT 13.x from this window. (image below):
(i am not able to paste picture here)
NOTE
: Make sure the CMD window states the following
a. “
Setting SDK Environment relative to C:\Program Files\Microsoft
SDKs\Windows\v7.x
b. Targeting Windows Server 2003
x64 DEBUG
c. Change to your Working directory (directory where your .cas, dat and .c file reside)
d. Launch Fluent: “C:\Program Files\ ANSYS Inc\v130\fluent\ntbin\win64\fluent
you can find this pdf file in fluent users website.
KK
Old   February 2, 2012, 10:15
laurentb's Avatar
Laurent B
First of all, i recommend you read the Fluent UDF Manual.
If you use a udf you will need to compile your code (.c file) in order to obtain a compiled library (.dll). You don't have to do this if someone give you the library precompiled BUT the library works only for a specific OS (32 or 64bits) and a specific solver (2d or 3d or double precision).
In your case you haven't got a library compiled for your OS (64bits) and your solver (3ddp)
Old   April 1, 2012, 15:13
Default sdk command prompt
  #11
David Ndeevelo
Makafa is on a distinguished road
Hi, i have visual studio 9 and in the sdk i dont see a command prompt, cant i start ufd for fluent using visual studio command prompt?
Makafa is offline   Reply With Quote
Old   July 20, 2012, 17:03
mila_oliv is on a distinguished road
I'm having this problem too, but my windows and the visual studio are 64bits...also I copied a udf that i knew it was right and it was compiled correctly and I succed to load the library. My own codes, on the other hand, i cant compile nor load the library.....
This can't be a system problem, right?
What am i doing wrong?
I'm new at udf.....
mila_oliv is offline   Reply With Quote
Old   September 20, 2012, 14:54
Unhappy please help me
  #13
mehran
kerend is on a distinguished road
hi every body
i need this tutorial .is there anybody help me to find this tutorial with below name:
Heave and Pitch Simulation of Ship hull moving through head sea waves
i would be grateful if someone help me
my email is :mkerend2004@yahoo.com
kerend is offline   Reply With Quote
Old   September 20, 2012, 15:43
  #14
mehran
hi every body
Old   September 21, 2012, 21:46
Default Good Post
  #15
iman
imanmirzaii is on a distinguished road
Niiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiice it worked for me
I looooooooooooooove CFD Online!
rarnaunot likes this.
imanmirzaii is offline   Reply With Quote
Old   October 30, 2012, 03:23
PhanHuuQuocHung study at HoChiMinh City University of Technology
QuocHung_Phan is on a distinguished road
Hi, i use fluent 14, cfree4_1_pro and win7 x64
i've succesfully compiled my udf, but when i load it fluent says:
what should i do?
Thank you.
QuocHung_Phan is offline   Reply With Quote
Old   December 5, 2012, 10:54
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
still do we need to use the fluent from SDK platform?
Far is offline   Reply With Quote
Old   December 9, 2012, 14:51
Default udf compiling problem
  #18
behzad
bshahzamanian is on a distinguished road
hi friends
i have a problem, when i compile udf source file it builds well but when i load it this error apears:
open_udf_library: The system cannot find the path specified.
bshahzamanian is offline   Reply With Quote
Old   January 17, 2013, 17:44
natalie is on a distinguished road
thanks a lot for this thread!
was very helpful to me!
natalie is offline   Reply With Quote
Old   January 21, 2013, 08:00
Daan de Boer
daandb is on a distinguished road
Had the same problem, solution worked like a charm. Tnx!
daandb is offline   Reply With Quote
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
