UDF Codes of Lattice Boltzman Methods
Old   April 14, 2021, 06:03
Default UDF Codes of Lattice Boltzman Methods
SUNIRMAL KARMAKAR
S_Karmakar is on a distinguished road
Hey everyone,
We know that Lattice Boltzmann method is used to study many classical aspects of fluid flow including phase change. But I was wondering how we can use LBM in form of UDF in ANSYS FLUENT to solve any fluid flow cases.
If anyone has any idea or any thoughts about it, YOU ARE MOST WELCOME TO SHARE.
ITS VALUABLE FOR ME.
SUNIRMAL KARMAKAR
PhD in Ceramic Engineering.
National Institute of Technology
Rourkela.
skarch1994@rediffmail.com
S_Karmakar is offline   Reply With Quote
Old   April 14, 2021, 13:31
pakk will become famous soon enough
You can code anything in a UDF, so in theory you can make LB solver in a UDF. But why would you? If you can do that, it is smarter to make a stand-alone LB solver...
So I would ask back: why in Fluent? Fluent is a finite volume solver, not LB. Which part of Fluent do you hope to use?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build".
pakk is offline   Reply With Quote
lbm
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 12:43
Replicating Scalable Wall Function with a UDF yousefaz FLUENT 0 August 4, 2017 02:30
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 06:12
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
