April 14, 2021, 06:03 |
UDF Codes of Lattice Boltzman Methods
SUNIRMAL KARMAKAR
Hey everyone,
We know that Lattice Boltzmann method is used to study many classical aspects of fluid flow including phase change. But I was wondering how we can use LBM in form of UDF in ANSYS FLUENT to solve any fluid flow cases. If anyone has any idea or any thoughts about it, YOU ARE MOST WELCOME TO SHARE. ITS VALUABLE FOR ME.
SUNIRMAL KARMAKAR PhD in Ceramic Engineering. National Institute of Technology Rourkela. skarch1994@rediffmail.com |
April 14, 2021, 13:31 |
Rep Power: 26 |
You can code anything in a UDF, so in theory you can make LB solver in a UDF. But why would you? If you can do that, it is smarter to make a stand-alone LB solver...
So I would ask back: why in Fluent? Fluent is a finite volume solver, not LB. Which part of Fluent do you hope to use?
"The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform" is NOT the error after compiling. It is the error after loading. To see compiler errors, look at your screen after you click "build". |
lbm |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 12:43 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
