How to get data of mass fraction in UDF
Old   March 9, 2020, 11:05
Default Command
  #61
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are you using double quotes around the command? The command needs to have bracket around it but no double quotes.
Secondly, contours of species mass fraction will always exist if species transport is enabled. What I suggested you to check is if the species mass fraction gradient exist or not. These will be available only after issuing the command. Furthermore, which Fluent version are you using? If the version is older than 13.0, then you will not be able to use this command.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 9, 2020, 11:52
mahdi rostami
mahdi-united is on a distinguished road
no this message exactly wrote by me:
(rpsetvar 'species/save-gradients? #t)
and contour of species mass fraction gradients not exist!!!
also contour of vapor pressure not exist too but contour of volume fraction, temperature , velocity, density, pressure gradients exist
my version in 19.5
mahdi-united is offline   Reply With Quote
Old   March 9, 2020, 12:38
Default rpsetvar
  #63
vinerm's Avatar
Vinerm
If Fluent is not accepting the command to save species gradients then there is problem with the case setup. Species gradients can be extracted without this command as well, using the standard UDF commands as you were doing earlier, however, the command does the same thing. If the command is not working, there is some issue with your case setup. It could either be related to multiphase or species transport setup.
Regards,
Vinerm
Old   March 9, 2020, 13:00
mahdi rostami
yes your right
i investigate it and say you
thank you very mich
Old   March 10, 2020, 08:39
mahdi rostami
please send your email for me
mahdi1372rs@gmail.com
Old   August 4, 2020, 02:07
Debojit Sharma
scorpian is on a distinguished road
Look at the source listing in your installation
./ansys_inc/vXXX/fluent/fluentXX.Y.Z/src
How to calculate the gradient of species mole fraction in fluent?
scorpian is offline   Reply With Quote
Old   August 5, 2020, 01:05
Default How to calculate gradient of species mole fraction in fluent?
  #67
Debojit Sharma
T_derivatives function is declared in pbns/sg.h, however, I do not think that it is relevant for you. You need to fetch gradients of mass fractions of species. That is accessible via C_YI_G or as stated earlier, using SV_Y_G, 0.
What error do you get if you use either C_YI_G or SV_Y_G? I would recommend the former since that is an easy wrapper for users.
Hello sir,
I was trying to get calculate the gradients of species mass and mole fraction in fluent. I could find the command for gradient of species mass fraction from your chat in this platform.
Could you help me how to get the gradient of species mole fraction in ANSYS-FLUENT?
Thanking you in anticipation,
With warm wishes,
Debojit Sharma
macros, segmentation error, udf
mass fraction of species Lilly FLUENT 5 March 13, 2022 17:52
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Accessing the species mass fraction for particles data in UDF mac_09 FLUENT 17 August 9, 2017 20:15
Define mass flow profile with regards to species mass fraction danS Fluent UDF and Scheme Programming 0 June 20, 2017 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
