UDF to Define Temperature Dependent Negative Heat Source
Old   September 9, 2019, 13:06
Default UDF to Define Temperature Dependent Negative Heat Source
Amitav tikadar
ATIKADAR is on a distinguished road
I am trying to calculate the average temperature of interface at each iteration (since I am solving steady state problem) and based on the interface temperature I want to update my negative heat source value (Q_Source=(-constant*(T_Interface-T_Constant))/volume). First, I tried UDM to store interface temperature but didn't work. Then I tried to GLOBAL variable to avoid UDM, but again no luck. I am using ANSYS FLUENT 2019 R2. For both cases, I Interpreted the UDF and during the interpretetion, FLUENT didn't show any error. I have attached my written UDF below. Can someone please help me to fix the problem?
Thanks in advance.
/*********UDF with UDM**********/
#include "udf.h"
/*********INTERFACE TEMPERATURE**************/
DEFINE_EXECUTE_AT_END(average_interface_temp_of_wi ndings_air)
Domain *d;
face_t f;
real temper = 0.0;
real A[ND_ND];
real tsavg=0.0;
real area = 0.0;
real area_tot = 0.0;
int ID = 10; /*this is the ID of the interface that I want to get the temperature from*/
Thread *t;
d = Get_Domain(1);
t = Lookup_Thread(d,ID);
/*We are trying to calculate area weighted average temperature of a surface- as per the definition of area weighted average*/
begin_f_loop(f,t)
F_AREA(A,f,t); /*get face area which is a vector*/
area = NV_MAG(A);/*get magnitude of the face area*/
area_tot += area; /*calculate total area*/
temper = F_T(f,t); /*calculate face temperature*/
tsavg += temper*area;
end_f_loop(f,t)
tsavg /= area_tot;
printf("Average Interface Temperature = %g\n",tsavg);
begin_f_loop(f,t)
F_UDMI(f,t,0) = tsavg; /* User Define Memory */
end_f_loop(f,t)
/**********NEGATIVE HEAT SOURCE***************/
DEFINE_SOURCE(negative_heat_source,c,t,dS,eqn)
real source;
face_t f;
source = -5000.*(F_UDMI(f,t,0)-290.); /* For the time being, I have assumed an arbitrary constant for hA and T_Sat */
dS[eqn] = 0.; /* Need to double check. It can be -5000. as a resultant of the derivative of source term */
return source;
/******UDF with Global Variable***********/
#include "udf.h"
real tsavg=0; /* Defining Global Variable */
DEFINE_EXECUTE_AT_END(average_interface_temp)
Domain *d;
face_t f;
/*real tsavg=0;*/
real temper = 0.0;
real A[ND_ND];
real area = 0.0;
Thread *t;
d = Get_Domain(1);
begin_f_loop(f,t)
end_f_loop(f,t)
tsavg /= area_tot;
DEFINE_SOURCE(heat_source,c,t,dS,eqn)
real source;
source = -5000.*(tsavg-300.); /* For the time being, I have assumed an arbitrary constant for hA and T_Sat */
return source;
ATIKADAR is offline   Reply With Quote
Old   September 23, 2019, 03:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
if you are using 2019R2 -> it means you run your code in parallel, but it was not considered
you have to modify your code:
Ansys Fluent Customization manual
-> Global Reduction Macros
other problem
real source;
face_t f;
in F_UDMI(f,t,0) f is not defined cause you dont have any loops through faces. Define_source has a build in loop over cells
fix these issues first
best regards
AlexanderZ is offline   Reply With Quote
fluent - udf, udf source, udf source energy
Adding temperature dependent heat source using fvOptions in chtMultiRegionSimpleFoam shaileshbg OpenFOAM Running, Solving & CFD 14 January 26, 2024 18:48
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 03:50
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 18:13
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
