September 13, 2019, 05:40 |
Explanation of a UDF codes
Josh
Rep Power: 7 |
Hi guys,
I am trying to apply a UDF to move one of the wall of a cubic tank in order to generate wave in the fluid inside. Regarding these thread I found: UDF for moving wall (oscillating) udf for sinusoidally oscillating wall It seems that I am in a very similar case, because I need to move just one of the faces (let's say along the x-axis for example) to obtain the effect. Essentially I do not grasp if these codes are moving one wall back and forth, because the key point of simulation is that my wall goes REALLY back and forth between a starting and an ending position (following a cosinusoidal law for the x-velocity that I wrote). Do they do this? In which part? |
September 23, 2019, 05:17 |
Alexander
Rep Power: 34 |
#include "udf.h" #include "dynamesh_tools.h" DEFINE_CG_MOTION(oscillate,dt,vel,omega,time,dtime ) { Thread *t; face_t f; /* define the variables */ t = DT_THREAD(dt); begin_f_loop(f,t) /* loop over each face in the zone to create an array of data */ { vel[0]= sin(time); } end_f_loop(f,t) } best regards |
motion wall, sloshing tank 2d, sloshingtank3d, udf code, udf customize |
UDF for vapor pressure | anuarun | Fluent UDF and Scheme Programming | 12 | December 24, 2021 10:12 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
Source Term UDF VS Porous Media Model | pchoopanya | Fluent UDF and Scheme Programming | 1 | August 28, 2013 06:12 |
DEFINE_GEOM UDF Problems | Pat | FLUENT | 0 | August 14, 2003 13:16 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
