ploting Line surfaces parell to x axis not ISO surfaces |
November 17, 2019, 23:57 |
MEK
Rep Power: 9 |
for ploting the iso surfaces parallel to x axis i use following scheme command
(Do ((x -0.004 (+ x 0.0005))) ((> x 0.027)) (Ti-menu-load-string (format #f "surface iso-surface x-coordinate x=~a , , ~a ," x x)) ) for y axis i just change the x in x-coordinates with y i got successfull in ploting line surfaces in vertical directions i.e. parallel to y-axis by using following command (Do ((x -0.004 (+ x 0.0005))) ((> x 0.0271)) (Ti-menu-load-string (format #f "su line-surface x=~a ~a -0.0015 ~a 0.0015" x x x)) ) but i want to plot LINE-SURFACES not iso-surfaces parallel to x-axis i.e. horizantal but i m unsuccessful if someone guide me then it will be very helpful Thanx in advance |
November 18, 2019, 00:04 |
#2 | |
MEK
Rep Power: 9 |
Never mind get successful |
November 18, 2019, 00:08 |
MEK
Rep Power: 9 |
actually i m calculating bulk temperature in a 2D domain thats why i am using these surfaces
my procedure is simple plot these lines write ascii files with the information of velocity and temperature then by using the matlab i am calculating the bulk temperature to calculate Nusselt number. if anyone want to recommend any thing regarding this procedure than always welcome |
November 18, 2019, 09:30 |
Rep Power: 26 |
Impressive. Every successful use of scheme is impressive.
But I don't know if it is efficient use of your time; depending on how you define bulk temperature, you might not need Matlab at all and can do everything in Fluent. |
November 19, 2019, 00:26 |
#5 | |
MEK
Rep Power: 9 |
i have digged deep this forum regarding discussion of bulk temperature as stated by LuckyTran working out for bulk temperature by doing this method its a very bad guess. but the recommended method is to develop custom field function for every surrface i.e. integral/sum of temperature * velocity and divide it by intergral/sum velocity but creating it for every surface is kind of donkey work but here scheme command comes for help to automatically make monitors for every surface. for wall temperature make the vertex average of points. (Ti-menu-load-string (format #f "s m su set tu~a ~s tu x=~a () no no yes tu~a 1 yes flow-time" x "Integral" x x)) (Ti-menu-load-string (format #f "s m su set u~a ~s velocity-magnitude x=~a () no no yes u~a 1 yes flow-time" x "Integral" x x)) (Ti-menu-load-string (format #f "s m su set tw~a ~s temperature point-~a () no no yes tw~a 1 yes flow-time" x "Vertex Average" x x)) but for averaging over time i still have to use matlab to sum the information over time. i know we can use data sampling for time averaging but i havent fully explored this idea. i hope when u say it can be done all by fluent u mean all of the above procedure or am i missing something |
November 19, 2019, 01:24 |
Rep Power: 26 |
Yes, I mean all of the above. It might all be possible in Fluent without Matlab or Scheme, but that completely depends on how you define bulk temperature. I have no idea what is your definition.
November 19, 2019, 01:46 |
#7 | |
MEK
Rep Power: 9 |
my bad https://ibb.co/jgSwf2f |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Problems of Duns Codes! | Martin J | Main CFD Forum | 8 | August 14, 2003 23:19 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
