udf for flow behaviour of dissimilar materials in friction stir welding process |
March 12, 2020, 07:45 |
Rohan
Rep Power: 6 |
I am using ANSYS Fluent and facing difficulty on how to write udf for visualizing the material flow behaviour in dissimilar materials in fsw process. N.B. The udf should be dependent on temperature, strain rate and follows Zener hollowman equation. |
March 12, 2020, 08:45 |
Fluid Flow
The objective of CFD is to predict the flow of fluids, dissimilar or not, based on the first principles. Zener-Holloman is just a parameter defining a constitutive relation between temperature and strain rate. Though this constitutive relation can be used in a CFD simulation, it does not really make much sense to use it.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Simulation of Friction Stir Welding of Pipe Butt Joints | keysersoze | ANSYS | 0 | November 26, 2018 03:50 |
Friction stir welding simulation | sid4512587 | FLUENT | 2 | November 23, 2016 21:05 |
Analysis of Friction Stir Welding | vishnuprakashs | Structural Mechanics | 0 | April 6, 2016 03:23 |
The fl process could not be started because of UDF | majid_kamyab | Fluent UDF and Scheme Programming | 6 | December 15, 2015 08:42 |
friction stir welding | raj | FLUENT | 1 | December 20, 2009 14:18 |
