Divergence & Floating Point Error on using UDF |
June 15, 2020, 03:53 |
Divergence
Do you get divergence at the very first iteration? In that case, you need to ensure that all the denominators are non-zero and all the sources are comparatively small. Since you are using field values in the UDF, a good initial guess is also important. So, you may try running the solution for a few iterations before hooking the source UDFs.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Divergence Problem Conjugated Heat Transfer | Christoph.Ha | FLUENT | 27 | December 5, 2017 10:46 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
[blockMesh] error EOF in blockMesh | Ahmed Khattab | OpenFOAM Meshing & Mesh Conversion | 7 | May 17, 2012 00:37 |
Primitive error at node- Floating point exception / continuity divergence issues | phales15 | FLUENT | 0 | April 30, 2011 19:05 |
divergence in AMG and floating point | grzes | FLUENT | 0 | February 17, 2006 13:22 |
