Face index using array -UDF
Prev Previous Post   Next Post Next
Old   July 29, 2020, 02:03
Default Face index using array -UDF
Arun raj.S
arunraj is on a distinguished road
Hello everyone,
Can you explain the concept of face index using array ?. It is required when calculating the difference between heat flux between two common faces of velocity inlet boundary condition. Is there any workaround other than this form. It would be a great help for me as I am struggling with this problem for a long time.
arunraj is offline   Reply With Quote
UDF code for Interior Face (Missile Nozzle Exit) Prabhumsrit Fluent UDF and Scheme Programming 7 January 8, 2018 12:29
Having trouble adapting serial UDF to work in parallel muyuntao Fluent UDF and Scheme Programming 1 November 10, 2015 13:42
FvMatrix coefficients shrina OpenFOAM Running, Solving & CFD 10 October 3, 2013 14:38
[OpenFOAM] Paraview 3.98 - errors when saving geometry file pajot ParaView 1 September 28, 2013 10:45
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
