An error which is received signal SIGSEGV in an udf file
Old   July 28, 2020, 05:58
Default An error which is received signal SIGSEGV in an udf file
Sumz
Su M Z is on a distinguished road
I’ve written an UDF file for the phase change in multiphase flow. VOF model and species transport were applied. The calculation was well converged in the initial several time steps, but an error occurred when the time step came to a specific value. The error is:
Node 1: Process 19654: Received signal SIGSEGV.
After examination, the UDF file could be well complied and loaded. The initialization of calculation is OK. And there is no gradient of macro parameters appeared in the UDF file.
What is the most possible reason to this problem? I need your help. Thanks a lot!
Su M Z is offline   Reply With Quote
Old   July 29, 2020, 01:12
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
could be everything: mesh, boundary conditions, UDF, material properties.
you didn't provide any information
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
udf,error ,vof
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
