Indefinite hold when executing DEFINE_ON_DEMAND |
November 18, 2020, 23:16 |
Hosea Chan
Rep Power: 7 |
Dear forum users,
I am currently writing a code that sums the volume for 4 cell zones at the before the initialization, which the values will be used in 4 subsequent DEFINE_SOURCE macros. Specifically, I need to apply an x-momentum force that is dependent on the average velocity at the upstream face of the cell zone and apply the force evenly to the fluid body within the cell zone. Here is the portion of the code I have written for the volume sum: Code:
#include "udf.h" #define cell_zones 4 real total_volume[cell_zones]; real Ux[cell_zones]; int id_a[cell_zones] = {28,33,37,40}; /* get zone id of channel-in later, need input */ int id_v[cell_zones] = {9,10,11,12}; /* get zone id of channel volume later, need input */ DEFINE_ON_DEMAND(initialize) { #if !RP_HOST Domain* d; int i; d = Get_Domain(1); for (i=0; i<4 ; i++) { Message0("Begin loop %d\n",i); cell_t c; Thread* t2 = Lookup_Thread(d,id_v[i]); begin_c_loop(c, t2) { total_volume[i] += C_VOLUME(c,t2); } end_c_loop(c, t2) Message0("End loop %d\n",i); #if RP_NODE total_volume[i] = PRF_GRSUM1(total_volume[i]); #endif node_to_host_real_1(total_volume[i]); Message0("total_volume of zone %d: %12.4e\n", i,total_volume[i]); } #if RP_NODE #endif /* RP_NODE */ #endif /* !RP_HOST */ } Best regards, Hosea Chan Last edited by Hosea_Chan; November 19, 2020 at 02:03. |
November 19, 2020, 04:13 |
Alexander
Rep Power: 34 |
#include "udf.h"
#define cell_zones 4 real total_volume[cell_zones]; real Ux[cell_zones]; int id_a[cell_zones] = {28,33,37,40}; /* get zone id of channel-in later, need input */ int id_v[cell_zones] = {9,10,11,12}; /* get zone id of channel volume later, need input */ DEFINE_ON_DEMAND(initialize) { #if !RP_HOST Domain* d; int i; d = Get_Domain(1); for (i=0; i<4 ; i++) { Message0("Begin loop %d\n",i); cell_t c; Thread* t2 = Lookup_Thread(d,id_v[i]); begin_c_loop(c, t2) { total_volume[i] += C_VOLUME(c,t2); } end_c_loop(c, t2) Message0("End loop %d\n",i); #if RP_NODE total_volume[i] = PRF_GRSUM1(total_volume[i]); #endif Message0("total_volume of zone %d: %12.4e\n", i,total_volume[i]); } #endif /* !RP_HOST */ }
best regards ****************************** press LIKE if this message was helpful |
November 19, 2020, 04:23 |
Hosea Chan
Rep Power: 7 |
Dear Alex,
Thank you so much! The code works! So it seems like it is the line of node_to_host_real1(total_volume[i]); is holding up the macro. As I have defined total_volume as a global variable, do I need to transfer it back to the host so that the variable can be used in the subsequent macros? Thanks! Best regards, Hosea |
November 19, 2020, 20:55 |
Alexander
Rep Power: 34 |
usually, you want to return values to host in cases:
1. you want to read/write from/to file 2. you want to transfer values to cortex (to use in scheme code for instance) so most likely you don't need to transfer. But if you are going to transfer, read how to make it for arrays Ansys Fluent Customization manual
November 20, 2020, 07:09 |
Hosea Chan
Rep Power: 7 |
Dear Alex,
Thank you very much for your clear explanation! This is a great help over the manual text! Best regards, Hosea |
Does Stokes hypothesis still hold for compressible flow? | TurbJet | Main CFD Forum | 6 | February 20, 2018 02:46 |
"epsAvg_0", "epsMax_0" and "epsMin_0" after executing foamLog | KeiJun | OpenFOAM Running, Solving & CFD | 0 | October 20, 2015 10:35 |
Force fluent to hold only last timestep | ansys_matt | FLUENT | 3 | August 24, 2014 22:07 |
Hold up in a closed vessel | Pascale Fonteijn | CFX | 4 | June 9, 2003 12:27 |
