March 2, 2014, 02:13 |
steady state for a standing ultrasonic wave
I intend to simulate an ultrasonic standing wave by using an pressure inlet with a reflector. The pressure inlet is supposed to oscillate sinusoidal to generate the wave. Now the question: Is it possible to generate the steady state by using a .ttab profile while the time step size is much larger than the profile step sizes?
Do I need to calculate in the same time step size as the profile step size is? What could be the alternative to simualte this if Iīm only interested in the steady state and therefore donīt want to calculate in the transient mode? Thanks a lot! |
November 25, 2015, 10:58 |
Hello flueth,
have you been able to generate te ultrasonic wave? am actually facing similar problem : i want to simulate the ultrasonic field generated by 2 transducers mounted on a pipe with streaming water. please see attached.. i would be thankful for help WP_20151125_16_48_48_Pro.jpg Last edited by houss; November 25, 2015 at 11:00. Reason: bad url |
November 27, 2015, 08:14 |
Rick
Rep Power: 26 |
I don't know if this can be simulated in steady state: from my point of view, no, because in a standing wave, waves continuously interact..If you look at the transducer it will never reach a steady state, as it continues to oscillate.
I simulated in the past simple ultasonic waves in water, in 2d and 3d, with the approach of a udf, compiled with the DEFINE_GRID_MOTION macro: this means you must know the displacement that your transducer produces.
Google is your friend and the same for the search button! |
November 27, 2015, 08:48 |
#4 | |
what is udf? i am actually intending to set up the simulation for openfoam. All i know about the transducer is that the emitted wave frequency is about 1MHz and some other information related to emitted longitudinal and transversal waves. Do you mean with Displacement the wave height on a free surface of water? Best regards Houssam. |
November 27, 2015, 09:05 |
Rick
Rep Power: 26 |
I mean the dispacement of the tip of the transducer or of the plate.
I was inspired by this article (from page 5 of the pdf): http://www2.arnes.si/~mdula/Numerica...ic%20field.pdf Maybe it can help. Udf is a user define function, to expand the capabilities of fluent. Maybe you can look at the openfoam section of this forum.
November 27, 2015, 10:10 |
ah ok. My plan was to define a sinusoidal pressure BC at the tranducer location. You are right it seems to make more sense to rather define a periodic displacement somehow.. the journal's paper seems to be interesting. I have also to take the generated acoustic cavitation into account because it will affect the fluid proporties (density, viscosity) and hence the wave propagation velocity ..
have you used a dynamic mesh for your simulations? |
November 27, 2015, 10:15 |
Rick
Rep Power: 26 |
Yes, the DEFINE_GRID_MOTION" defines o moving/deforming mesh.
I also included liquid compressiblity, by including an udf for density and speed of sound.
November 27, 2015, 10:26 |
sounds good.
Surely i have also to define appropriate functions in OpenFoam. Unfortunately there are here no threads discussing the issue for openfoam. I would be very thankful if i could have a look into your udf ghost82 |
September 11, 2017, 15:30 |
ultrasonic waves
#9 | |
ken mingzhi
Rep Power: 9 |
I connected transducer from upstream and downstream sides how can i define its boundary conditions? |
December 13, 2020, 10:21 |
#10 |
Mohammad
Rep Power: 10 |
hello there
I wanna simulating a ultrasonic probe in fluent with moving mesh can you help me with your experience thanks |
standing wave, steady, ultrasonic |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Solver for transonic flow? | Martin Hegedus | OpenFOAM Running, Solving & CFD | 22 | December 16, 2015 04:59 |
is it possible to predict how long it takes to reach steady state solution in unstead | Alimohamadi_nasr | CFX | 4 | November 11, 2013 06:11 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
