December 8, 2020, 03:40 |
six dof issue
ali
Rep Power: 5 |
Hi every one, hope you be healthy
I am simulating a moving guide vane in the water pipe with FLUENT, the guide vane only can rotates in one direction, the guide vane rotates by torque that water stream imposes, I use SIX-DOF to simulate it but when I want to see the motion with display zoon motion, the guide vane does not move and FLUENT gives this warning: Warning: unable to read motion history file D:/Master/Final Project/ansys/AZAR/17dynamic mesh/fluent_guide.6dof. Pictures are attached. Best regard. |
December 9, 2020, 02:28 |
Alexander
Rep Power: 34 |
1. check if this file exists in folder
2. may be the problem in the folder name, which contains space symbol inside Code:
17dynamic mesh TO BE: 17dynamic_mesh
best regards ****************************** press LIKE if this message was helpful |
December 9, 2020, 04:56 |
#3 | |
ali
Rep Power: 5 |
Are you know what the problem is and how I can create it? |
December 9, 2020, 13:55 |
Rep Power: 26 |
Alexander already identified a problem. You have a space in your folder name (two even). Fix that problem first, see if it helps.
Issue on zeroGradient BC for system rotation | magnushaese | OpenFOAM Running, Solving & CFD | 2 | January 28, 2022 13:43 |
rhoCentralFoam inviscid airfoil issue (Foam::error::printStack(Foam::Ostream&) at ??) | kmkb21 | OpenFOAM Running, Solving & CFD | 1 | March 1, 2018 01:07 |
Prism Layer - Core Mesh Boundary Issue | InfernoxCJC | STAR-CCM+ | 7 | November 21, 2017 15:46 |
foamToTecplot360 issue with multiregion solvers | manuc | OpenFOAM Post-Processing | 2 | November 21, 2016 13:51 |
Pressure boundary condition issue | Vijay | FLUENT | 0 | April 6, 2012 13:35 |
