April 25, 2022, 18:04 |
particles wall interaction
angelo
Rep Power: 4 |
hello guys i created this UDF that works without error but i see that when the particle in injected it is not affected by the lateral force and i do not know why.
I post the UDF. Thanks in advance /* UDF adding an external body force to the particles */ #include "udf.h" #include "dpm.h" #include "dpm_mem.h" #include "surf.h" DEFINE_DPM_BODY_FORCE(particle_body_force, p, i) { /* declaration of variables */ double w, Dh, Ufx, Ufy, Ufz, Gx, rho, a, F_L, c_height, c_length, c_volume, side, H, W, f_height_total, Renx, Reny, Renz, crDh, mu, aUfx, aUfy, aUfz, C1, C2, C3, C4, C_Ly, C_Lz, z, y, distancewall, cosine; real xw[ND_ND]; real vec[ND_ND]; Domain* d; cell_t c; Thread* t; face_t f; //f is the face index that is inside the face thread t(our wall). You will extract the face area vector from f index d = Get_Domain(1); c = P_CELL(p); //cell in witch the particle is currently in t = Lookup_Thread(d, 9); //9 is the ID number of the upper wall. t is the thread index(pointer) of the wall boundary surface 9 distancewall = 100; //i'm setting an generic initial value begin_f_loop(f, t) { F_CENTROID(xw, f, t); //center of each face NV_VV(vec, =, xw, -, P_POS(p)); //vector connecting the particle to the face center that is placed at the wall. The NV_VV do the operation between 2 vectors vec=xw-P_POS(p)) if (distancewall >= NV_MAG(vec)) { distancewall = NV_MAG(vec); } } end_f_loop(f, t) //i'm doing a double cicling of all faces of the thread. I start with distancewall=100 and then i compare it with the distance of the particle respect to a certain face centroid\\ //if distancewall is bigger than that value, you fix it equal to them and then you do again a comparin but with the next face centroid. if is not more bigger you close the loop //and you get the minimum distance. Thread* tt = P_CELL_THREAD(p); H = 0.00005; /*height of the cross section of the channel */ W = 0.0001; /*width of the cross section of the channel */ Dh = 0.00006667; /*hydraulic diameter of the channel */ mu = 0.001003; /*viscosity of the fluid */ rho = C_R(c, tt); Ufx = C_U(c, tt); Ufy = C_V(c, tt); Ufz = C_W(c, tt); aUfx = fabs(Ufx); /* absolute value of Ufx */ aUfy = fabs(Ufy); /* absolute value of Ufy */ aUfz = fabs(Ufz); /* absolute value of Ufz */ /* local Reynolds number calculation*/ Renx = (rho * aUfx * Dh) / mu; Reny = (rho * aUfy * Dh) / mu; Renz = (rho * aUfz * Dh) / mu; Gx = (Ufx) / H; /*max shear rate of the channel*/ a = P_DIAM(p); /* particle diameter */ y = fabs(((H / 2) - distancewall) / (H / 2)); C1 = -3.0374; C2 = -0.3046; C3 = 0.9790; C4 = -0.0016; C_Ly = C1 * pow(y, 3) + C2 * pow(y, 2) + C3 * pow(y, 1) + C4 * pow(y, 0); //valido nel primo e secondo quadrante if (i == 1) { if (distancewall <= H / 2) { F_L = rho * pow(Gx, 2) * pow(a, 4) * C_Ly; } else { F_L = -rho * pow(Gx, 2) * pow(a, 4) * C_Ly; } } t = Lookup_Thread(d, 8); distancewall = 100; //i'm setting an generic initial value begin_f_loop(f, t) { F_CENTROID(xw, f, t); //center of each face NV_VV(vec, =, xw, -, P_POS(p)); //vector connecting the particle to the face center that is placed at the wall. The NV_VV do the operation between 2 vectors vec=xw-P_POS(p)) if (distancewall >= NV_MAG(vec)) { distancewall = NV_MAG(vec); } } end_f_loop(f, t) cosine = vec[i] / (NV_MAG(vec)); //this is the cosine director because vec[i] is the i component of the vector vec Thread* ttt = P_CELL_THREAD(p); rho = C_R(c, ttt); Ufx = C_U(c, ttt); Ufy = C_V(c, ttt); Ufz = C_W(c, ttt); aUfx = fabs(Ufx); /* absolute value of Ufx */ aUfy = fabs(Ufy); /* absolute value of Ufy */ aUfz = fabs(Ufz); /* absolute value of Ufz */ /* local Reynolds number calculation*/ Renx = (rho * aUfx * Dh) / mu; Reny = (rho * aUfy * Dh) / mu; Renz = (rho * aUfz * Dh) / mu; Gx = (Ufx) / H; /*max shear rate of the channel*/ a = P_DIAM(p); /* particle diameter */ z = fabs(((W / 2) - distancewall) / (H / 2)); if (z >= 0 && z <= 1.2) { C_Lz = ((0.047 - y * (0.077 / 0.6)) / 1.2) * z; } else if (z > 1.2) { C_Lz = (7.3046 * ((y * (0.077 / 0.6)) - 0.127) * pow(z, 2) - 17.531 * ((y * (0.077 / 0.6)) - 0.127) * z + 9.51863 * ((y * (0.077 / 0.6)) - 0.135405)); /*value of C_L for 2z/H */ } if (i == 2) { if (distancewall <= W / 2) { F_L = (rho * pow(Gx, 2) * pow(a, 4) * C_Lz)*cosine; } else { F_L = -(rho * pow(Gx, 2) * pow(a, 4) * C_Lz)*cosine; } } if (i == 0) { if (distancewall <= W / 2) { F_L = (rho * pow(Gx, 2) * pow(a, 4) * C_Lz)*cosine; } else { F_L = -(rho * pow(Gx, 2) * pow(a, 4) * C_Lz)*cosine; } } Message("x position:%g\n", P_POS(p)[0]); Message("y position:%g\n", P_POS(p)[1]); Message("z position:%g\n", P_POS(p)[2]); return (F_L / P_MASS(p)); } |
April 25, 2022, 22:50 |
Alexander
Rep Power: 34 |
__________
best regards ****************************** press LIKE if this message was helpful |
strange stuck particles on the rebound wall in MPPICFoam | carye | OpenFOAM Running, Solving & CFD | 12 | April 4, 2022 07:52 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
UDF for wall slipping | HFLUENT | Fluent UDF and Scheme Programming | 0 | April 27, 2011 12:03 |
