January 7, 2021, 03:50 |
velocity slip and temperature jump
zhangdongjie
Rep Power: 5 |
I'm simulating a nozzle with rarefied gas. Its kn number is very large. First order slip and temperature jump must be added. I use Maxwell slip equation to write UDF, but I don't know where UDF should be loaded. I look up the data. The sliding speed can be loaded into the shear stress, so where is the temperature jump loaded? Is it loaded directly into the wall temperature? But my wall temperature is fixed at 300K. If anyone has a compiled UDF file, can you send me one? Thank you very much.1248385182@qq.com
Velocity slip and temperature jump UDF | zhangdongjie | FLUENT | 1 | October 15, 2021 03:17 |
How to set slip velocity and temperature jump | awuunity | CFX | 10 | July 2, 2018 08:40 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Implementation of maxwell slip velocity and Temperature jump with openfoam | yassepid | OpenFOAM | 2 | June 28, 2016 07:05 |
2-d axisymmetric microtube flow with velocity slip and temperature jump b.c. | dayashankar | FLUENT | 1 | May 18, 2016 21:45 |
