UDF for Nucleation site density - contact angle - latent heat |
January 20, 2021, 09:30 |
Kevin Fontaine
Rep Power: 6 |
Good morning,
I am trying to write a UDF to implement the Hibiki-Ishii formulation of the Nucleation site density in my Fluent simulation and there are 4 points for which I would appreciate some help: 1)This formulation depends on the contact angle. I was wondering if there was a way to access the contact angle value using a macro as Fluent has to calculate it to determine the bubble departure diameter when the Kocamustafaogullari - Ishii formulation is used to assess it or if I had to compute the contact angle within the UDF. I could not find any macro yet. In the surface tension tab of the phase interaction window, I do use surface Tension Force Modelling using a continuum Surface Force and a constant value of the surface tension. 2)Is it possible to access, using a macro, the Standard State Enthalpy specified in the material properties? Indeed, I need the latent heat for the Hibiki - Ishii formulation of the nucleation site density. Right now I define the latent heat within the UDF but having access to it would be more convenient. 3)I would also like to know what will the macro C_R(c0,pt0[gas_phase]) give if there is no gas in the cell. 4) I have trouble to understand how the lines to get the specified surface tension work, specifically the line starting with the pointer property definition and the T_sfc definition. (I got that part in the customization manual where the surface tension is retrieved in the example 2 of DEFINE_EXCHANGE_PROPERTY.). I could not find any explanation about the macro used in the manual nor elsewhere. here is the code for now: Code:
#include "udf.h" #define Nn_bar 4.72e5 #define mu 0.722 #define lambda_prim 2.5e-6 #define R 8.31 #define lat_heat 3.966077e4 DEFINE_BOILING_PROPERTY(nucleate_site_density,f,t,c0,t0,from_index,from_species_index,to_index,to_species_index) { // f : wall face // t : pointer to the wall face thread // c0 : cell index of the cell next to the wall // to : pointer to mixture level thread // from_index : Liquid phase // from_species_index : ID of liquid species // to_index : Vapor phase // to_species_index : ID of vapor species real nuc_site_d, T_sfc, rho_plus, f_rho_plus, Rc, sigma, theta; int liq_phase = from_index; int gas_phase = to_index; Thread **pt0 = THREAD_SUB_THREADS(t0); real T_SAT = C_STORAGE_R(c0,t0,SV_SAT_TEMPERATURE); real T_l = C_T(c0, pt0[liq_phase]); real rho_g = C_R(c0,pt0[gas_phase]); real rho_l = C_R(c0,pt0[liq_phase]); real P_l = C_P(c0,pt0[liq_phase]); real T_g = C_T(c0,pt0[gas_phase]); /* ------ Get surface tension ------ */ Property *prop = DOMAIN_COMPLEX_PROP_PROPERTY(DOMAIN_INTERACTION(root_domain), COMPLEX_PROP_sfc_tension_coeff,liq_phase,gas_phase); T_sfc = (sg_temperature && NNULLP(THREAD_STORAGE(pt0[liq_phase],SV_T)))? C_T(c,pt0[liq_phase]) : T_REF; if(prop == NULL || PROPERTY_METHOD(prop,0) == PROP_METHOD_NONE) { Error("Hibiki-Ishii nucleation site density: Please set value for surface tension !"); } sigma = generic_property(c,t,prop,(Property_ID)0,T_sfc); if (sigma < 0.) { Error("Hibiki-Ishii nucleation site density: Please provide a nonzero value for surface tension"); } /*------------------------------------*/ theta = rho_plus = log10((rho_l - rho_g)/rho_g); f_rho_plus = -0.01064 + 0.48246*rho_plus - 0.22712*rho_plus^2 +0.05468*rho_plus^3; Rc = (2*sigma*(1+(rho_g/rho_l))/P_l)/(exp(lat_heat*(T_g - T_SAT)/(R*T_g*T_SAT)-1); nuc_site_d = Nn_bar*(1-exp(-theta/(8*mu^2)))*(exp(f_rho_plus*lambda_prim/Rc)-1); return nuc_site_d; } |
contact angle, latent heat, nucleation site density, surface tension |
UDF for dynamic Contact Angle | Wolfgang.Black | FLOW-3D | 0 | May 26, 2020 15:20 |
How to deal latent heat during phase change through source term udf | dkb_bg | Fluent UDF and Scheme Programming | 4 | April 12, 2018 20:26 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
