February 25, 2021, 08:29 |
Velocity_inlet profile UDF parallelization
Nima
Rep Power: 11 |
Hi everyone!
I've been trying to parallelize the velocity inlet UDF in order to run it on the parallel solver. As it should be running on an HPC cluster it is not possible to use the expression for inlet boundary condition and UDF interpretation doesn't work there. Code:
/***********************************************************************/ /* Velocity.c */ /* UDF for specifying steady-state velocity profile boundary condition */ /***********************************************************************/ #include "udf.h" DEFINE_PROFILE(inlet_x_velocity, thread, position) { real x[ND_ND]; /* this will hold the position vector */ real y; face_t f; begin_f_loop(f, thread) { F_CENTROID(x,f,thread); y = x[1]; F_PROFILE(f, thread, position) = (y/.005); /* it is just an example */ } end_f_loop(f, thread) } https://www.afs.enea.it/project/nept...df/node230.htm I'd appreciate your help. Thanks Last edited by nima_nz; February 25, 2021 at 09:34. |
February 25, 2021, 11:22 |
Rep Power: 26 |
It might just work without any changes, did you try that already?
UDF Parabolic 2D Velocity Profile Issue | chrislyn | FLUENT | 2 | December 11, 2018 12:11 |
Fluent udf "DEFINE_PROFILE" parallelization | uconcorde | Fluent UDF and Scheme Programming | 1 | May 7, 2018 02:47 |
defining temperature profile with UDF | mohammadkm | Fluent UDF and Scheme Programming | 11 | July 3, 2013 00:15 |
Read profile file from UDF | DonQuijote | Fluent UDF and Scheme Programming | 0 | February 18, 2013 11:56 |
Ansys FLUENT UDF - Velocity profile (of known values) across edge / surface | emmkell | Fluent UDF and Scheme Programming | 2 | October 21, 2011 13:12 |
